IdentifyTask for dynamic map services
1264
07-10-2012 06:50 AM
MayJeff
Can you identify all the layers in different dynamic map services using identifytask?  This sample here only shows for one map service:
http://resources.arcgis.com/en/help/flex-api/samples/index.html#/Identify_features/01nq0000000z00000...
If not, how do you identify all polygon layers in multiple map services?
Thanks.
RobertScheitlin__GISP
Jeff,
   You can find all the code you need in the Identify Widget.
http://www.arcgis.com/home/item.html?id=39cf66d58c234279ba728c50461a1a89
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Jeff,
   You have to loop though all the map services in the map and send an identify task to the server for each one.
MayJeff
Jeff,
Can you shows me a simple sample to get some ideas on the code?  That would be great !
Jeff,
