How to select and copy specific text from Infowindow to clipboard
2062
08-31-2011 08:09 AM
ShravanBonagiri
Hi All,
I would like to select specific text from the Infowindow and copy it to clipboard. Right now I am able to copy entire window. But my requirement is to select specific string and copy it to clipboard. Any help would be appreciated.
Here is my code:
private function onMapClick(event:MapMouseEvent):void
    var latlong:MapPoint = WebMercatorUtil.webMercatorToGeographic(event.mapPoint) as MapPoint;
    myMap.infoWindow.label = "Lat/Long: " + latlong.y.toFixed(6) + "/ " + latlong.x.toFixed(6);
    myMap.infoWindow.show(event.mapPoint);
    System.setClipboard(myMap.infoWindow.label);
Sam
ShravanBonagiri
I am still looking for help with this problem. Have you guys had any work around solution for it.
Hi All,
Here is my code:
Sam
YungKaiChin
What is the specific string that you want to copy to your clipboard? The Lat and Long value?
ShravanBonagiri
Yes! I want to copy Lat value separately and Long value separately, if possible.
YungKaiChin
Since you already have two values, you can simply use them and format the string to whatever you want.
For example:
System.setClipboard(latlong.y.toFixed(6).toString() + "\n" + latlong.x.toFixed(6).toString());
However, notepad does not support regular expressions, so you will have to paste it into a word doc.
