How to configure the find task to search for layers in multiple services...
1258
09-12-2011 02:50 PM
ZlatkoGrebenar1
I am using code from the samples (Zoom to found features). I got it to work on searching for fields in one service just like the example shows.
How can I add multiple find tasks in order to search multiple services?
Any code or help is very much appreciated.
Zlatko
YungKaiChin
Declare multiple FindTasks and run them.
You can create them inside
<fx: Declarations>
</fx: Declarations>
ZlatkoGrebenar1
HI YungKai,
Script:
private function doFind1():void
    findTask.execute(myFindParameters);
   private function executeCompleteHandler1(event:FindEvent):void
    myGraphicsLayer.clear();
    resultSummary.text = "Found " + event.findResults.length + " results.";
    myGraphicsLayer.symbol = sfsFind;
    var resultCount:int = event.findResults.length;
    if (resultCount == 0)
     Alert.show("No parcels found. Please change your search.");
    else
     // add feature as graphic to graphics layer
     for (var i:int = 0; i < resultCount; i++)
      var graphic:Graphic = FindResult(event.findResults).feature;
      graphic.toolTip = event.findResults.foundFieldName + ": " + event.findResults.value;
      myGraphicsLayer.add(graphic);
     // zoom to extent of all features
     var graphicProvider:ArrayCollection = myGraphicsLayer.graphicProvider as ArrayCollection;
     var graphicsExtent:Extent = GraphicUtil.getGraphicsExtent(graphicProvider.toArray());
     map.extent = graphicsExtent.expand(1.4); // zoom out a little
Declarations:
<esri:FindTask id="findTask2"
        executeComplete="executeCompleteHandler1(event)"
        url="**************"/>
<esri:FindParameters id="myFindParameters"
        contains="true"
        layerIds="[3]"
        outSpatialReference="{map.spatialReference}"
        returnGeometry="true"
        searchFields="[SubName]"
        searchText="{fText.text}"/>
Am I on the right track here or am I missing something?
Zlatko
YungKaiChin
Yes, you are.
However, you may need to think a bit more when to execute two findTasks, and how to deal with the results.
