Flex 3.6 SDK - for flash player 9
1569
09-09-2011 01:10 AM
MarkHorsell
Help.
Is there a library available which is compatible with the 3.6 SDK? as i have to target flash player 9. If so where can i find it.
MarkHorsell
Found this.
http://resources.arcgis.com/CONTENT/arcgis-flex-api-download
would be VERY useful if i knew which of these were compatible with 3.6 (or any other) without having to download and try all of them.
MarkHorsell
Found this, which does indicate which flash player versions are targeted.
http://resources.arcgis.com/content/requirements-arcgis-api-flex
YungKaiChin
You should be able to find the info inside the sdk folder ...
The default location should be something like ...
C:\Program Files\Adobe\Adobe Flash Builder\sdks\
Click the version of sdk folder and click frameworks.
Open flex-config.xml ...
You should find the info <target player> ...</target player>
