How do you get a MapPoint from a MultiPoint on MouseEvent?
1206
05-05-2010 11:53 AM
EricTerpstra
If I click a specific MapPoint (represented by a SimpleGraphicSymbol) within a MultiPoint, how can i retrieve the information for only the point that was clicked.  Here's the code displaying the MultiPoint:
  <esri:GraphicsLayer id="glDeviceLayer"
   symbol="{deviceMarker}">
   <esri:Graphic id="glDevicePoints"
    click="pointClick(event)">
    <esri:geometry>
     <esri:Multipoint id="multipoint"
      points="{mapPoints}" />
    </esri:geometry>
   </esri:Graphic>
  </esri:GraphicsLayer>
ZahidChaudhry
Heres something you can do in actionscript
private function onMouseClick(event:mouseEvent):void{
var mygraphic:Graphic = event.currentTarget as Graphic;
if (mygraphic){
var myMapPoint:Mappoint = Mappoint (mygraphic.geometry);
var lat:number = myMapPoint.y;
var lon:number = myMapPoint.x;
I havent got chance to test, but i know it will work (may be little bit tunning need because of upper/lower case letter and spellings) - hope it will help
Zahid
http://zachsgeospatial.blogspot.com
EricTerpstra
Unfortunately this does not work.  A MultiPoint object is an array of MapPoints, so when I click on a point on the map, event.currentTarget returns a MultiPoint, which cannot be coerced as a MapPoint.  I need a way to distinguish which MapPoint within the MultiPoint was clicked, and as var as I can tell, neither event.target nor event.currentTarget will return this information.
It seems like this should be basic functionality, but I guess a MultiPoint is intended to be one cohesive graphic.  The only solution I can think of is to not use a MultiPoint, but rather loop over my lat/long data and manually add individual MapPoints to the map so that they can each be clicked.
RobertScheitlin__GISP
eterps,
   You are on the right track in thinking that a multipoint graphic is intended to be treated as an single graphic.
the only solution I can think of is to not use a MultiPoint, but rather loop over my lat/long data and manually add individual MapPoints to the map so that they can each be clicked.
This would be your best route.
