Getting a bitmap of a DynamicMapServiceLayer
1521
04-20-2010 01:54 PM
MichaelHayden
Hello,
In the API for DynamicMapServiceLayer class there is the following entry in protected methods:
zoomStartHandler(event:ZoomEvent):void
Prepares the zoom animation by taking a bitmap of the layer.
My question is as follows:
How can I get a bitmap of a DynamicMapServiceLayer?
Thank You
MichaelHayden
So I got the layer as a bitmap. Here's the code (any comments would be appreciated):
public class GraphicLayerThresholding extends ArcGISDynamicMapServiceLayer
     private  function _init():void
          _thresholdLayerBitmapData = getLayerAsBitmap(this as UIComponent);
     static public function getLayerAsBitmap(fromTarget:UIComponent, area:Rectangle = null):BitmapData
            var bd : BitmapData = new BitmapData( _map.width, _map.height, true, 0x00000000 );
     bd.draw( fromTarget, m );
     return bd;
MichaelHayden
One of the master programmers here at work pointed out the method exportMapImage which returns a url reference to the image that fills the ArcGISDynamicMapServiceLayer that I am extending. I then load that image usingactionscripts Loader class. from there I can get the bitmapdata of the image/layer. This worked out perfectly for me. Now I can do bitmap manipulation on the layer. Any response or words of advise would be greatly appreciated.
  override protected function updateLayer():void
   graphics.clear();
   var imageParams:ImageParameters = new ImageParameters();
   imageParams.height = map.height;
   imageParams.width = map.width;
   imageParams.format = 'png32';
   var mapImage:MapImage = new MapImage();
   this.exportMapImage(imageParams, new AsyncResponder(onResult, onFault));
  private function onFault(info:Object, token:Object = null):void
   Alert.show(info.toString(), "Export Problem");
  private function onResult(mi:MapImage, token:Object = null):void
   var loader:Loader = new Loader();
   loader.contentLoaderInfo.addEventListener(Event.COMPLETE, completeHandler);
   loader.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
   var request:URLRequest = new URLRequest(mi.href);
   loader.load(request);
  private function completeHandler(event:Event):void {
   var loader:Loader = Loader(event.target.loader);
   _image = Bitmap(loader.content);
   _updateGraphic(_image, _thresholdValue);
Michael L. Hayden
Web Application Developer
Data Transfer Solutions
Fort Collins, Denver
(970) 472-0032 (phone)
www.dtsagile.com
DasaPaddock
Here's an example of getting to the loaded tiles in a tiled layer and modifying their bitmapData. The same could be done for a dynamic layer.
http://forums.esri.com/Thread.asp?c=158&f=2421&t=303099#948090
MichaelHayden
Thanks for replying dpaddock,
I did happen upon the link you suggested when I first started creating this widget. The example did serve me well. Then I was introduced to extending the ArcGISDynamicMapServiceLayer and that made for a more elegant solution. In my overriding of the updateLayer() method (which fires when changes occur to the layer i.e. map extent change, pan, etc), I'm retrieving an image copy of the layer from the esri server, clearing this layers graphics (this.graphics.clear()),  applying thresholding adjustments and filling my layer's graphics parameter with the thresholding adjustment's resulting bitmapData.
Michael L. Hayden
www.dtsagile.com
