Editnig without Editor , Show info Window in drawEnd
1104
10-07-2010 04:31 AM
ZahyHwary
Hi Every body
I am using darwTool , editTool , and templateinpector to build my Editor Component as my buisness needs , but I am facing a problem , I need to open the InfowWindow and when I draw a new Feature , just like Editor component does ,I.e. the attributeInspector should appear in infoWindow when draw a new feature , so user shouldn't click the newly created feature to has this done ,
I am using a query object and give it the geometry from EndDrawEvent , and then use this query object in my  feature layer as the following :
protected function draw_drawEndHandler(event:DrawEvent):void
                     for each (var layer:Layer in myMap.layers)
    if (layer is FeatureLayer)
     var l:FeatureLayer = layer as FeatureLayer
     queryMapClick.geometry = event.graphic.geometry;
      l.selectFeatures(queryMapClick, FeatureLayer.SELECTION_NEW);
the problem exactly in query object it throws Fault:4000 unable to perform Query .
Please help , thanks
JasonPatterson
I suggest opening an incident ticket with Support Services, they should be able to assist.
SarthakDatt
Hey Zahy,
The attributeInspector works with the selected feature(s) on a feature layer. In your case you can select the newly created feature based on its object(unique) id.
e.g:
     var featureLayer:FeatureLayer = templatePicker.selectedTemplate.featureLayer; // current featureLayer
     featureLayer.addEventListener(FeatureLayerEvent.EDITS_COMPLETE,featureLayer_editsCompleteHandler); // listening for edits complete
     featureLayer.applyEdits([ event.graphic ], null, null);     // saving the newly created feature
private function featureLayer_editsCompleteHandler(event:FeatureLayerEvent):void
      var addResult:FeatureEditResult = event.featureEditResults.addResults[0];
      if (addResult.success === true)
            var query:Query = new Query();
            query.objectIds = [ addResult.objectId ];
            event.featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW);  // selecting the newly created feature
AttributeInspector.activeFeature property would be updated with selection complete. You could now show the infoWindow with the attributeInspector for the newly created feature.
Hope that helps.
ZahyHwary
Hi Sarthak
thanks for help , this works fine with me 🙂
