Concatenate query string in a Loop?
3949
02-04-2014 07:08 AM
ionarawilson1
I need to add a OR expression to a query depending on the values in a loop. So for example if I have three related records , how can I create two OR expressions to add to the definition expression, which each attribute value added to the OR expression? Thanks
It would be something like this, with each objectidstring being a different object id:
var defexpr:String =  "OBJECTID" +  " like " +  "'"  +  objectidstring + "'" " OR " + "OBJECTID" +  " like " +  "'"  +  objectidstring + "'" " OR " + "OBJECTID" +  " like " +  "'"  +  objectidstring + "'"
     function onResult(relatedRecords:Object, token:Object = null):void      {        // get related records for the first feature       var fset:FeatureSet = (relatedRecords[event.features[0].attributes.OBJECTID]);       if (fset is FeatureSet)       {           relatedRecordsCount = fset.attributes.length;        numberofrelatedrecords.text = relatedRecordsCount.toString()        for (var i=0, il=fset.attributes.length; i<il; i++)        {           var objectidstring:String = String(fset.attributes.OBJECTID)            Alert.show(objectidstring)                }               var defexpr:String =  "OBJECTID" +  " like " +  "'"  +  objectidstring + "'";        var defexpr2:String =  " OR " + "OBJECTID" +  " like " +  "'"  +  objectidstring + "'"        yourTable.definitionExpression = defexpr               Alert.show(defexpr)        query.where = defexpr;        query.objectIds=[];        query.returnGeometry = false;        queryTask.executeForIds(query);
AnthonyGiles
Honored Contributor
Ionara,
You need to do a check on the first line so it doesn't get an or added to the front, something like:
var defexpr:String = ""
      if (i=0)
          defexpr =  "OBJECTID" +  " =" +  fset.attributes.OBJECTID
      else
          defexpr = defexpr + " or " + "OBJECTID" +  " = "  +  fset.attributes.OBJECTID
Regards
Anthony
BjornSvensson
Esri Alum
If your OBJECTID field is not a string field, you probably need to drop the quotes  around the values.
Not really a direct answer to your question, but assuming your OBJECTID field is not a string field you probably should use "=" instead of "LIKE".
And if you're ending up with multiple OR based on the same field, you're usually even better of changing it into an "IN" statement, for example:
OBJECTID in (1,2,3,10,11,101)
AnthonyGiles
Honored Contributor
Ionara,
      if (i=0)
      else
Regards
Anthony
ionarawilson1
Thank you all for your help! Anthony's solution worked for me:
Thank you so much Anthony!!!
          //var objectidstring:String = String(fset.attributes.OBJECTID)
           //Alert.show(objectidstring)
        if (i == 0)
        else
       Alert.show(defexpr)
       query.objectIds=[];
       myAttributeTable.featureLayer = myFeatureLayer
       myAttributeTable.featureLayer = yourTable
       myAttributeTable.visible = true;
       yourTable.visible = true
