check if files exist on server?
4602
29
09-06-2010 05:01 AM
NatashaManzuiga
Hi, how can I test if an image files exist on server in Flex 3.0?
Thanks in advance
NatashaManzuiga
Naty,
   With the code you just posted you are attempting to load a PDF file into an image control which is not supported. There is no PDF viewer component in Flex by default.
Sorry it was just a sample...I corrected it...
Thanks.
Naty
NatashaManzuiga
Thanks.
Naty
Hi Robert...I corrected it but it still doesnt work 😞
Is there another function to do this that work with PDF files?
Naty!
RobertScheitlin__GISP
Naty,
   What is the string that you are passing in for the imgx? Is it the same as the nameBuilding?
public function IOErrorEventHandler(imgx:String):void {
var loader:Loader = new Loader();
loader.contentLoaderInfo.addEventListener (Event.COMPLETE, onComplete);
loader.contentLoaderInfo.addEventListener(IOErrorE vent.IO_ERROR, ioErrorHandler);
var request:URLRequest = new URLRequest(imgx);
loader.load(request);
private function onComplete (evt : Event) : void
var nameBuilding:String = Building1.selectedItem.@dgn;
nameBuilding="CleanPrintA4/" + nameBuilding.toString().substr(0,nameBuilding.leng th-4) + ".pdf";
var u:URLRequest = new URLRequest(nameBuilding);
navigateToURL(u, "_blank");
private function ioErrorHandler(event:IOErrorEvent):void {
NatashaManzuiga
Naty,
Yes Robert, I tried with full and relative path too..but it doesnt work anyway.
Naty
NatashaManzuiga
Hi Robert,
Could u test this function with a pdf file?
Cheers,
Naty
Naty,
     You can only use the loader object for certain types of images. It will not work for pdf files. If you had a trace statement in your error function you could see that it is error with an unknown file type error. If you Google how to verify that a file exists on the server you will see that this has to be done with server side code like PHP or ASP.
DasaPaddock
If you're only trying to test if you get an error or not, you could try using a URLLoader instead of a Loader.
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/net/URLLoader.html
Dasa,
   Thanks for the tip.
Naty,
   Based on Dasa's advice this works:
    var loader:URLLoader = new URLLoader();
    loader.dataFormat = URLLoaderDataFormat.BINARY;
    loader.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
    loader.addEventListener(ProgressEvent.PROGRESS, onComplete);
    trace(event.toString());
NatashaManzuiga
Dasa,
   Thanks for the tip.
Naty,
Many thanks Dasa and Robert...
I finally fixed it...
Robert is it possible to run this OnComplete function from the menu?
I wish I could launch PDF by the menu...based on "Building1.selectedItem.@dgn"
Cheers,
Naty
NatashaManzuiga
Cheers,
Naty
Hi all, I almost solved my problem..
1) I added a "link" in config.xml
2) I modified the function "menuItemClick()" in the ControllerMenuItem.mxml and  by the "label" value I assigned at my link I can call all the URL I want by code...so I can bypass the URL in config.xml.
My problem is that I still cant get the value in my MiniSearch widget...
How can I get the value Robert?
Naty
