check if files exist on server?
4627
29
09-06-2010 05:01 AM
NatashaManzuiga
Hi, how can I test if an image files exist on server in Flex 3.0?
Thanks in advance
NatashaManzuiga
I sent u the Minisearch and the XML source 🙂 I wish I could select building and plan passing @dgn value...
Thank u soooooo much,
Naty
Naty,
   Sure it's possible can you post your MiniSearch.mxml?
NatashaManzuiga
Naty
RobertScheitlin__GISP
Naty,
   Hmm... Explain to me the desired work flow?
Right now even your xml is malformed...
Should look like this
<?xml version="1.0" encoding="utf-8"?>
<Buildings>
    <Building name='1'>
        <Plan code='P1' dgn='1p1.dgn'/>
        <Plan code='PT' dgn='1pt.dgn'/>
        <Plan code='S1' dgn='1s1.dgn'/>
     </Building>
    <Building name='11O'>
        <Plan code='PT' dgn='11opt.dgn'/>
        <Plan code='S1' dgn='11os1.dgn'/>
    </Building>
</Buildings>
NOT
 <Plan code='S1' dgn='11os1.dgn'/Plan>
NatashaManzuiga
Robert, yes u are right!!
Sorry I sent u the first version of my XML and u have to replace "/Plan" with "/" but u know this.
What I want to do is that after I performed a query from SearchWidget I obtain RecordData as result....when I click one record I stored a variable named DGN that is the same of these related combobox...so it should work like this: I click the record I pass the DGN value and this set the corresponding Building and Plan in this minisearch widget. like to show where I am 🙂
I hope I m clear now. 🙂
Naty
Naty,
<Buildings>
    <Building name='1'>
     </Building>
    </Building>
</Buildings>
NOT
Naty,
   Took me a little while to find the time but here is the solution.
this.parentApplication.miniSearch.Building.selectedItem = this.parentApplication.miniSearch.dp.Building.Plan.(@dgn == "1pt.dgn").parent();
    this.parentApplication.miniSearch.Plan.selectedItem = this.parentApplication.miniSearch.dp.Building.Plan.(@dgn == "1pt.dgn");
NatashaManzuiga
Naty,
Thanks so much Robert!!
I still have refresh problem with the dependent combobox...Plan..
Sometimes if I dont run two times this code...it doesnt work :confused:
Naty
NatashaManzuiga
Hi Robert!!
Thanks, I tried with the following code:
Now I want to ask u how can I set a value to the MiniSearch widget textbox from the SearchWidget..Can u help me with this?
       public function IOErrorEventHandler(imgx:String):void {
          var loader:Loader = new Loader();
          loader.contentLoaderInfo.addEventListener (Event.COMPLETE, onComplete);
          loader.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
          var request:URLRequest = new URLRequest(imgx);
          loader.load(request);
      private function onComplete (evt : Event) : void
                  infoImage.source = "Images/" + infoData.title + ".jpg";
    infoImage.height = 150;
    infoImage.width = 190;
    infoImage.visible = true;
    infoImage.includeInLayout = true;
      private function ioErrorHandler(event:IOErrorEvent):void {
    infoImage.visible = false;
    infoImage.includeInLayout = false;
Hi Robert,
It doesnt work with PDF... :((((
Can u help me?
Naty
Naty,
   What doesn't work? What are you trying to do? What does your code changes look like when you try to make this work for pdfs? This was a while ago that I help you with this and I am not even sure what you were doing here...
NatashaManzuiga
Naty,
Hi Robert.
I can perfectly check if there is a .jpg file in my server. I m so thankful to u about this!
I want to use the same code that u see below to test if there is a PDF file or not but it doesnt work 😞
Naty
    var nameBuilding:String = Building1.selectedItem.@dgn;
    nameBuilding="CleanPrintA4/" + nameBuilding.toString().substr(0,nameBuilding.length-4) + ".pdf";
    var u:URLRequest = new URLRequest(nameBuilding);
    navigateToURL(u, "_blank");
Naty,
   With the code you just posted you are attempting to load a PDF file into an image control which is not supported. There is no PDF viewer component in Flex by default.
