check if files exist on server?
4648
29
09-06-2010 05:01 AM
NatashaManzuiga
Hi, how can I test if an image files exist on server in Flex 3.0?
Thanks in advance
RobertScheitlin__GISP
Natty,
    Try something like this:
loader.contentLoaderInfo.addEventListener(IOErrorE vent.IO_ERROR, imgLoadErrorMethod);
NatashaManzuiga
Natty,
Hi Robert!!
Thanks, I tried with the following code:
Now I want to ask u how can I set a value to the MiniSearch widget textbox from the SearchWidget..Can u help me with this?
       public function IOErrorEventHandler(imgx:String):void {
          var loader:Loader = new Loader();
          loader.contentLoaderInfo.addEventListener (Event.COMPLETE, onComplete);
          loader.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
          var request:URLRequest = new URLRequest(imgx);
          loader.load(request);
      private function onComplete (evt : Event) : void
                  infoImage.source = "Images/" + infoData.title + ".jpg";
    infoImage.height = 150;
    infoImage.width = 190;
    infoImage.visible = true;
    infoImage.includeInLayout = true;
      private function ioErrorHandler(event:IOErrorEvent):void {
    infoImage.visible = false;
    infoImage.includeInLayout = false;
Natty,
   Can you be a little more specific? Are you wanting to send the image that you got to the MiniSearch or just a string value? I need to have a clear idea of your desired work flow.
NatashaManzuiga
Natty,
Hi Robert, just a string value to the MiniSearch widget  :)))
Naty
Naty,
   OK I need just a little bit more. Remind me you put the MiniSearch in your Index.mxml right? Does the MiniSearch have an id attribute and if so what is it? Basically we will have to get a reference to the MiniSearch throught the SearchWidget using parrentApplication and then using the id of the minisearch and the id of the textInput.
NatashaManzuiga
Naty,
Robert, yes I put the MiniSearch in my index.html
how can I get the Id?
Naty
<SiteContainer id="container">
    <configManager> <ConfigManager/> </configManager>
       <uiManager>     <UIManager/>     </uiManager>
       <controller>    <Controller x="20" y="20"/>    </controller>
       <dataManager>   <DataManager/>   </dataManager>
       <widgetManager> <WidgetManagerDocked/> </widgetManager>
       <mapManager>  <MapManager/> </mapManager>
</SiteContainer>
<widgets:MiniSearch x="20" y="420" />
Naty,
   Add an id to the minisearch like so:
<widgets:MiniSearch id="miniSearch" top ="120" left="50"/>
   then you need to do call this from where ever
this.parentApplication.miniSearch.ti.text = "hello";
NatashaManzuiga
Naty,
Thank u so much Robert it fixes my problem!!
I read a XML to populate a combobox inside my MiniSearch...now I wish I could select a value from a click...Is it possible?
Naty
Naty,
   Sure it's possible can you post your MiniSearch.mxml?
