Call a GP Service in FlexViewer 2.3.1
4544
10
07-05-2011 07:37 AM
francescodi_vito
Hy guys
i develop a model ain ArcGis 10 and i publish it as a Map Service with a Tool Layer. The GP Service is Synchronus and he works very well. i need to change the GP Service in Asynchronous but i tried to change my script but don't works.
i post here my script for my model synchronus
<?xml version="1.0" encoding="utf-8"?>
// Copyright (c) 2010 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/License.txt
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
       xmlns:s="library://ns.adobe.com/flex/spark"
       xmlns:mx="library://ns.adobe.com/flex/mx"
       xmlns:esri="http://www.esri.com/2008/ags"
       xmlns:viewer="com.esri.viewer.*"
       height="192">
 <fx:Script>
  <![CDATA[
   import com.esri.ags.FeatureSet;
   import com.esri.ags.Graphic;
   import com.esri.ags.SpatialReference;
   import com.esri.ags.events.GeoprocessorEvent;
   import com.esri.ags.events.GraphicsLayerEvent;
   import com.esri.ags.events.MapMouseEvent;
   import com.esri.ags.geometry.Geometry;
   import com.esri.ags.symbols.SimpleFillSymbol;
   import com.esri.ags.symbols.SimpleLineSymbol;
   import com.esri.ags.symbols.SimpleMarkerSymbol;
   import com.esri.ags.tasks.Geoprocessor;
   import mx.controls.Alert;
   import mx.rpc.events.FaultEvent;
   private function startGeoProcess(event:MouseEvent):void
    var parms:Object = new Object();
    parms.Condizione = String(condizione.text);
    parms.Valore = Number(valore.text);
    var geoprocessTask:Geoprocessor = new Geoprocessor();
    geoprocessTask.outSpatialReference = map.spatialReference;
    geoprocessTask.showBusyCursor = true;
    geoprocessTask.url = "http://193.204.163.134/ArcGIS/rest/services/ENEA/Cap_Term_Vol_MAX/GPServer/CapTermVolMAX";
    geoprocessTask.useAMF = false;
    geoprocessTask.execute(parms);
    geoprocessTask.addEventListener(GeoprocessorEvent.EXECUTE_COMPLETE, executeCompleteHandler);
    geoprocessTask.addEventListener(FaultEvent.FAULT, faultHandler);
   private function executeCompleteHandler(event:GeoprocessorEvent):void
    var myPointSymbol:SimpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 12, 0x1AA1D3, 0.3);
    for each (var graphic:Graphic in event.executeResult.results[0].value.features)
     graphic.symbol = myPointSymbol;
     graphicsLayer.add(graphic);
     map.addLayer(graphicsLayer);
   private function faultHandler(event:FaultEvent):void
    if (event.type == "fault"
     && event.fault.name == 'Error'
     && event.fault.faultCode == '500'
     && event.fault.faultString == 'Error Executing Task')
     Alert.show("Oops - no results.  Try clicking in an ocean...");
    else
     Alert.show("Unexpected fault:\n" + event.toString());
 </fx:Script>
 <fx:Declarations>
  <esri:GraphicsLayer id="graphicsLayer"/>
 </fx:Declarations>
 <viewer:WidgetTemplate id="helloWorld"
         width="390" height="192">
  <s:Label text="RICERCA CAPACITA' TERMICA MIN" y="10" horizontalCenter="0" color="#000000" fontWeight="bold"/>
  <s:TextInput id="condizione"
      width="66"
      paddingLeft="0"
      paddingRight="0"
      text="&gt;" y="48" horizontalCenter="0" textAlign="center"/>
  <s:Label text="inserisci valore" y="76" horizontalCenter="0"/>
  <s:Button
   label="Ricerca"
   click="startGeoProcess(event)"
   bottom="5" left="10" cornerRadius="7"/>
  <s:Button
   label="Clear"
   click="graphicsLayer.clear()"
   bottom="5" right="9" cornerRadius="7"/>
  <s:TextInput id="valore"
      width="66"
      paddingLeft="0"
      paddingRight="0"
      text="2" y="92" horizontalCenter="0" textAlign="center"/>
  <s:Label text="inserisci operatore matematico ( &gt; / &lt; )" y="32" horizontalCenter="0"/>
 </viewer:WidgetTemplate>
</viewer:BaseWidget>
can anybody tell me how to modify my script for set my GP Service as Asynchronous?
help please
YungKaiChin
1. Make sure the service support asynchronous geoprocessing ... (it will show in the fault msg)
2. Change execute to submitJob geoprocessTask.submitJob(parms);
3. Change event executeComplete > jobComplete
The reference can be found here:
http://help.arcgis.com/en/webapi/flex/apiref/index.html?com/esri/ags/tasks/JobInfo.html&com/esri/ags...
IvanBespalov
http://193.204.163.134/ArcGIS/sdk/rest/index.html?gpserver.html - ArcGIS Server REST API
gpService.execute(params, new AsyncResponder(gpServiceResultHandler, gpServiceFaultHandler));
private function gpServiceResultHandler(data:Object, token:Object = null):void
{ //do smthing with results }
private function gpServiceFaultHandler(fault:Fault, token:Object = null):
{ //do smthing with faults }
Also in last Flex Viewer from ESRI you can find DataExtractWidget - it works with GPServices.
looking on your service, i cant find "SubmitJob" in supported operations
execute()
submitJob()
francescodi_vito
hi
in my service you don't see submitJob because i set it Synchronous. When i tried with submitJob i change the service property.
I try with your help and after i will wrote for the responce
francescodi_vito
can you give me a link for download the DataExtractWidget?
thanks
IvanBespalov
francescodi_vito
Hi Ivan, thanks.
Now i try the code that you give me and after i say you if it works good
thanks
IvanBespalov
Hmmm. Now I understood the meaning of your question.
:confused:
"ykchin" advised you how to solve you problem. No more - only 3 steps.
I just tried to show you where you can get help.
francescodi_vito
hi Ivan
I followed the instructions of "ykchin" but the model don't get me a result.
    geoprocessTask.addEventListener(GeoprocessorEvent.JOB_COMPLETE, executeCompleteHandler);
    var myPointSymbol:SimpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, 0x1AA1D3, 0.2);
    else
In your opinion is there a error?
With Synchronous model and the original code that i post, i have a result. But the model takes a long time to run and after 2 mitutes in my application i have a worning by plug-in of ShockWave Flash, because because it's been a long time.
What do you think?
Help
IvanBespalov
Sorry, but my English is so poor... i can't describe you how to... I tried to give you links to ESRI help.
Just feel the difference between
and
screen2.png (your service) - NOT support asynchronous geoprocessing
