Reverse Geocode a collection of MapPoints
1180
07-06-2011 04:52 AM
RedaKechouri
Hi all,
This might be quite obvious to some of you, bu I can't get my head around this problem : basically, I'm trying to reverse geocode a collection of points, but due to the Asynchronous nature of the Locator Task, I only get the last result populated...
Here is a bit of code, I must do something fundamentally wrong here :
private function getAddress(myPoints:ArrayCollection):void
 for each (var myPoint:Object in myPoints)
  locateTask.addEventListener(LocatorEvent.LOCATION_TO_ADDRESS_COMPLETE, locateTask_locationToAddressCompleteHandler);
  locateTask.locationToAddress(myPoint.point, 100);
  function locateTask_locationToAddressCompleteHandler(event:LocatorEvent):void
   var candidate:AddressCandidate = event.addressCandidate;
   if (candidate && candidate.address && candidate.address.Name)
    var address:Object = candidate.address;
    myPoint.address = address.Name;
   else
    myPoint.address = "N/A";
   locateTask.removeEventListener(LocatorEvent.LOCATION_TO_ADDRESS_COMPLETE, locateTask_locationToAddressCompleteHandler);
Many thanks for your help....
RobertScheitlin__GISP
Reda,
   Try separating out the result function and not removing the listener:
            private function locateTask_locationToAddressCompleteHandler(event:LocatorEvent):void
                if (candidate && candidate.address && candidate.address.Name){
                }else{
