Call a GP Service in FlexViewer 2.3.1
4546
10
07-05-2011 07:37 AM
francescodi_vito
Hy guys
i develop a model ain ArcGis 10 and i publish it as a Map Service with a Tool Layer. The GP Service is Synchronus and he works very well. i need to change the GP Service in Asynchronous but i tried to change my script but don't works.
i post here my script for my model synchronus
<?xml version="1.0" encoding="utf-8"?>
// Copyright (c) 2010 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/License.txt
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
       xmlns:s="library://ns.adobe.com/flex/spark"
       xmlns:mx="library://ns.adobe.com/flex/mx"
       xmlns:esri="http://www.esri.com/2008/ags"
       xmlns:viewer="com.esri.viewer.*"
       height="192">
 <fx:Script>
  <![CDATA[
   import com.esri.ags.FeatureSet;
   import com.esri.ags.Graphic;
   import com.esri.ags.SpatialReference;
   import com.esri.ags.events.GeoprocessorEvent;
   import com.esri.ags.events.GraphicsLayerEvent;
   import com.esri.ags.events.MapMouseEvent;
   import com.esri.ags.geometry.Geometry;
   import com.esri.ags.symbols.SimpleFillSymbol;
   import com.esri.ags.symbols.SimpleLineSymbol;
   import com.esri.ags.symbols.SimpleMarkerSymbol;
   import com.esri.ags.tasks.Geoprocessor;
   import mx.controls.Alert;
   import mx.rpc.events.FaultEvent;
   private function startGeoProcess(event:MouseEvent):void
    var parms:Object = new Object();
    parms.Condizione = String(condizione.text);
    parms.Valore = Number(valore.text);
    var geoprocessTask:Geoprocessor = new Geoprocessor();
    geoprocessTask.outSpatialReference = map.spatialReference;
    geoprocessTask.showBusyCursor = true;
    geoprocessTask.url = "http://193.204.163.134/ArcGIS/rest/services/ENEA/Cap_Term_Vol_MAX/GPServer/CapTermVolMAX";
    geoprocessTask.useAMF = false;
    geoprocessTask.execute(parms);
    geoprocessTask.addEventListener(GeoprocessorEvent.EXECUTE_COMPLETE, executeCompleteHandler);
    geoprocessTask.addEventListener(FaultEvent.FAULT, faultHandler);
   private function executeCompleteHandler(event:GeoprocessorEvent):void
    var myPointSymbol:SimpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 12, 0x1AA1D3, 0.3);
    for each (var graphic:Graphic in event.executeResult.results[0].value.features)
     graphic.symbol = myPointSymbol;
     graphicsLayer.add(graphic);
     map.addLayer(graphicsLayer);
   private function faultHandler(event:FaultEvent):void
    if (event.type == "fault"
     && event.fault.name == 'Error'
     && event.fault.faultCode == '500'
     && event.fault.faultString == 'Error Executing Task')
     Alert.show("Oops - no results.  Try clicking in an ocean...");
    else
     Alert.show("Unexpected fault:\n" + event.toString());
 </fx:Script>
 <fx:Declarations>
  <esri:GraphicsLayer id="graphicsLayer"/>
 </fx:Declarations>
 <viewer:WidgetTemplate id="helloWorld"
         width="390" height="192">
  <s:Label text="RICERCA CAPACITA' TERMICA MIN" y="10" horizontalCenter="0" color="#000000" fontWeight="bold"/>
  <s:TextInput id="condizione"
      width="66"
      paddingLeft="0"
      paddingRight="0"
      text="&gt;" y="48" horizontalCenter="0" textAlign="center"/>
  <s:Label text="inserisci valore" y="76" horizontalCenter="0"/>
  <s:Button
   label="Ricerca"
   click="startGeoProcess(event)"
   bottom="5" left="10" cornerRadius="7"/>
  <s:Button
   label="Clear"
   click="graphicsLayer.clear()"
   bottom="5" right="9" cornerRadius="7"/>
  <s:TextInput id="valore"
      width="66"
      paddingLeft="0"
      paddingRight="0"
      text="2" y="92" horizontalCenter="0" textAlign="center"/>
  <s:Label text="inserisci operatore matematico ( &gt; / &lt; )" y="32" horizontalCenter="0"/>
 </viewer:WidgetTemplate>
</viewer:BaseWidget>
can anybody tell me how to modify my script for set my GP Service as Asynchronous?
help please
francescodi_vito
Ivan also my english it's so poor
My GP Service support submitJob! and when i run the GP in REST he works very well.
But in Flex Viewer the model works but don't give me a graphic symbol that i set in my code.
This is the code
<fx:Script>
  <![CDATA[
    geoprocessTask.submitJob(parms);
    geoprocessTask.addEventListener(GeoprocessorEvent.JOB_COMPLETE, executeCompleteHandler);
    var myPointSymbol:SimpleMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, 0x1AA1D3, 0.2);
    else
 </fx:Script>
Why don't give me a graphic result?
Do you see any error in my code?
