I'm on 10.3.1, and my topology toolbar says it's showing, but is not displaying. Thoughts?
784
5
09-06-2016 09:22 AM
ElizabethChristenson1
I have an advanced concurrent use license.
DanPatterson_Retired
two monitors?
did you tile or cascade your windows?
did it ever appear?
DarrenWiens2
MVP Honored Contributor
See here for lots of ideas to fix a toolbar opening off screen, assuming that's the problem.
Thanks for the tips.  I have three monitors, I used up all the tips possible for trying to find the topology toolbar.  I see that it is selected and I've moved screens around, undocked all my toolbars that I have selected, did the registry change and delete.  There's lots of topics on changing parameters around if the toolbar is not working, but I still can't get the toolbar to show up on the screen anywhere.
BlakeTerhune
MVP Regular Contributor
As a last resort, you can try resetting your ArcGIS application profile.
IT WORKED!!
