Solved! Go to Solution.
I obtain acceptable TIN when the z tolerance is equal or higher than 1 unit. But when i test 0.5, 0.9 or even 0.999 values, my TIN becomes completely irrational (for example, the first half of my TIN is a perfect regular TIN with 1-meter edges, but the second half does not represent nothing, with 200-meters-edge triangles). It seems that 1 is a limit value for z tolerance, is this correct ? What can i do to test lower values than 1 ?
