Indeed, I tested this method (taking a z-factor of ten and a z tolerance value of 2) and it works well. I just wanted to understand the limit in the z tolerance value. But effectively, it seems that my z accuracy is around 1 meter, which creates more nodes than my limitation of points (1500000).
Thank you for your advice.
