z tolerance in "Raster to TIN" tool
2028
06-19-2013 06:53 AM
MangeantBaptiste
Hi !
I want to test different values of z tolerance with the "Raster to TIN" tool on an 1-meter-grid raster. I obtain acceptable TIN when the z tolerance is equal or higher than 1 unit. But when i test 0.5, 0.9 or even 0.999 values, my TIN becomes completely irrational (for example, the first half of my TIN is a perfect regular TIN with 1-meter edges, but the second half does not represent nothing, with 200-meters-edge triangles). It seems that 1 is a limit value for z tolerance, is this correct ? What can i do to test lower values than 1 ?
Thank you for your attention.
Mangeant Baptiste
French Engineering Student
Tags (1)
curtvprice
Are you sure you have this much Z accuracy in your elevation data? Is this going to create more than few million nodes?
If this is indeed a bug with the tool and not your data, you could scale your data by using a Z factor. This will scale your values by 100 so you can use smaller tolerances, for example, if the z_factor is set to 100,  a z_tolerance of 50 would represent 0.5.
curtvprice
MangeantBaptiste
Indeed, I tested this method (taking a z-factor of ten and a z tolerance value of 2) and it works well. I just wanted to understand the limit in the z tolerance value. But effectively, it seems that my z accuracy is around 1 meter, which creates more nodes than my limitation of points (1500000).
Thank you for your advice.
curtvprice
You may want to look into terrains, which can handle larger numbers of points and do this conversion on the fly when needed.
