Creating a 3D model out of a DEM
5384
07-08-2021 10:20 AM
IzzadeanMirghani
Hello,
I am struggling with something simple in ArcScene. I have created TINs and DEMs and turned them into 3D surfaces many times in the past but I am struggling for some reason now. I took a series of DEMs from USGS Earth Explorer and stitched them together in ArcMap to create one DEM. I then used this layer for all my geo-recessing. It is in the GCS_WGS_1984 coordinate system, which I did not think was an issue. When I try to select the "floating on a custom surface" selection, it turns my DEM into a weird blob/line figure instead of 3D.
To rectify this, I then used the project tool to change the coordinate system to WGS_1984_UTM_Zone_36N. It still does the same thing when I try to select the "floating on a custom surface selection".
Has anyone ever encountered this before? Is it a glitch?
JayantaPoddar
Could you share the extent of the layer (for each spatial reference)?
Think Location
DanPatterson
MVP Esteemed Contributor
add the dem to a new map with no other data or basemaps.... is it normal?
... sort of retired...
IzzadeanMirghani
The DEM functions normal in ArcMap and in ArcScene without other data or basemaps. It is only when I try to turn it into a 3D model that it starts behaving this way.
AbraKaiser
How did you turn your DEM into a surface? I'm trying to turn mine into a multipatch to do an intersection with other multipatches.
IzzadeanMirghani
Are you stitching the DEM layers together to create one continuous DEM raster and then turning it into the surface you want?
Here are some helpful links:
https://pro.arcgis.com/en/pro-app/2.8/tool-reference/conversion/multipatch-to-raster.htm
https://desktop.arcgis.com/en/arcmap/10.3/analyze/commonly-used-tools/surface-creation-and-analysis....
