This is the error i get with LasTools.
/ Anton
That's not much information... Would it be possible to share (a small part) of the information?
it worked one time.
I didn't know i could make the error window bigger, when i did it said error: no input
Then i tried change file-"format" in the input window. (see picture)
Then I managed to run it successfully twice but then the same problem appeared.
EDIT: It seems like it's necessary to have the input-file on the same drive as ArcGIS
So you made it work. I'm glad you could fix it!
Yes, Thank you.
I think that the problem was just that i have two drives on my laptop. The input file needs to be on the same drive as ArcGIS. The parse string i used for my ascii file (see above) was cxzy. It worked fine.
Thanks for all support,
Anton
@ClaytonCrawford we still need to convert TXT to LAS, any chance this could be prioritized with Pro 2.9. If so we can finally lay ArcMap to rest?
I don't think we every had a supported tool in ArcMap to do that conversion. A sample utility perhaps. We don't get many requests for this so it's hard to justify prioritizing a new tool for it in 2.9. Would a command line exe callable from a script based GP too suffice?
Hi Clayton.
Basically, I'm asking to have ASCII Text To LAS from 3D Sample Tools implemented in Pro ;o)
LAZ to zLAS and zLAS to LAZ are already part of Convert LAS so I was hoping that ASCII Text To LAS could be implemented in Conversion Tools/LAS?
Regards, Klaus
