Analyze clashes of service pipes in 3D
875
09-25-2010 11:05 PM
RameshMuthuraman
Is it possible to see clashes/crossing of service pipes in 3D ? Does the software highlights the locations of clashes ? if yes, please explain in detail.
Regards,
Ramesh
Gert_van_Maren
Hi Ramesh,
If your pipes are closed multipatches, then yes. You could do a 3D intersect and find the intersection pieces. If your pipes are lines, you could try using near3D.
Also we are working on extending the intersec3D tool to include lines.This will be available in 10.1
Regards Gert
Regards,
Ramesh
RameshMuthuraman
Thanks for your reply Gert. Which version of ArcGIS has this near3D function actually i am using ArcGIS 9.3.1. Is it possible to find the clashes in 9.3.?
Regards,
Ramesh
