3D Line Of Sight - Visibility From Roads
2828
09-07-2010 02:19 PM
ShaunWeston
I'm just wondering how to go about getting a map showing the visibility from roads to a certain observer point.
This was done in the International User Conference presentation and I haven't quite figured out how to get a birds eye view of the roads that are visible and the roads that are not visible to a certain observer point.
Attached is a jpg of what I'm after and also attached is a jpg of a model that I have built to try and achieve this, but it's not quite working correctly.
So, does anyone know the workflow to get a 2D map showing this?
Tags (1)
by Anonymous User
Not applicable
Original User: nath2869
Hi Shaun,
You're pretty close. After contructing the view lines to test and running Line of Sight (which it appears you have under control already), what I did was:
- Get all the visible points (the points where the visible LOS lines touch the roads)
- Buffer them by just a bit over half of the spacing distance (to create merged polygons)
- Intersect the visible-coverage polygons with the Road lines
-> The results are the road lines that are have a view to the building (including the 'error' margin)
I created a little graphical mockup image showing the steps - attached.
Thanks, Nathan.
ShaunWeston
Cheers Nathan
Yeah Buffering the point makes more sense. I'll give it a go and see what happens.
Thanks for the reply.
Shaun
