Add z-value to shapefile made of multipatch data (roofsurfaces)
9527
15
01-27-2018 06:43 AM
Jacob_JeffB
Hey guys, i am pretty new in 3D analysis in ArcMap/Scene (10.5.1.)
It might be pretty simple question ( and it hopefully is).
I am working with 3D buildings of my hometown to analyze roof solar potential.
My final goal is to produce slope and aspect data.
What kind of data i use:
-   109 multipatch (.gml) files (each contains GroundSurface, RoofSurface, Wallsurface)
>> i am interested in Roofsurfaces to analyze slope and aspect
-  1 shapefile (it contains the 109 roofsurfaces)
>> i produced it myself and used it for 2D analysis (for example: footprint to estimate and distinguish flat and sloping roof types)
What i am trying to do is:
- add z_value to the shapefile
- to create a raster elevation map
- and finally do slope and aspect analysis
My problem is:
- i dont know much about multipatch and gml. data
- i dont know how to create this z-value out of my existing data and add it the attribute table of the shapefile (if had the z-value i could use polygon to raster)
> Is it even possible? Can i use the shapefile? Or do i have to use the raw data (multipatch / gml.)
I hope you can understand what i am trying to do, and what kind of data i use.
Thanks in advance,
JacobB
XanderBakker
Esri Esteemed Contributor
I just noticed that in the screenshot before I used the DWG files that you can download at the same site which can be read directly using ArcGIS (no conversion required).
Jacob_JeffB
Thank you very much for helps. It unforunately still does not work. It is probably an issue with the computers/servers i am working on (at my university that provides free ArcGis Software). I think its time get in touch with the administrator.
Here is what i tried for DWG files. The tool was successfully finished. But the output data seems to be unusable.
This what i tried with the GML data. Same ERROR as above.
XanderBakker
I just wrote a script to process all the DWG files, but there seems to be a problem with some of them. When I have a (partial) result I will post it back here.
XanderBakker
Find below the code that I wrote to process the data (DWG files):
import arcpy
def main():
    import os
    # settings
    ws = r'C:\GeoNet\CityGML\DWG_LoD2'
    fgdb = r'C:\GeoNet\CityGML\gdb\Hannover.gdb'
    dsm_name = 'DSM'
    slope_name = 'Slope'
    aspect_name = 'Aspect'
    cellsize = 1.0
    sr = arcpy.SpatialReference(25832)  # ETRS_1989_UTM_Zone_32N
    # necessary environment settngs
    arcpy.env.outputCoordinateSystem= sr
    arcpy.env.workspace = ws
    # create list of DWG file in folder (ws)
    lst = arcpy.ListFiles("*.DWG")
    # check out SA license
    # loop through dwg file
    lst_ras = []
    lst_err = []
    for dwg in lst:
        dwg_mp = os.path.join(ws, dwg, 'MultiPatch')
        print("Processing: {}".format(dwg))
        # correct extent
        ext = arcpy.Describe(dwg_mp).extent
        ext_corr = CorrectExtent(ext, cellsize)
        arcpy.env.extent = ext_corr
        # define output raster name
        ras_name = 'ras{}'.format(os.path.splitext(dwg)[0])
        out_ras = os.path.join(fgdb, ras_name)
        # create raster from multipatch and add to lost
        try:
            # some files create a error. I will skip those
            arcpy.MultipatchToRaster_conversion(dwg_mp, out_ras, cellsize)
            lst_ras.append(out_ras)
        except Exception as e:
            print "ERROR: ", e
            lst_err.append(dwg)
    print "DWG that produced Errors:"
    print "\n - ".join(lst_err)
    # mosaic raster into new raster
    print("mosaic into new raster...")
    input_ras = ';'.join(lst_ras)
    arcpy.MosaicToNewRaster_management(input_ras, fgdb, dsm_name, sr, "32_BIT_FLOAT", cellsize, 1, "MEAN")
    # set extent to output DSM
    dsm_ras = os.path.join(fgdb, dsm_name)
    arcpy.env.extent = dsm_ras
    # calculate slope
    print("calculate slope...")
    slope_ras = os.path.join(fgdb, slope_name)
    out_slope = arcpy.sa.Slope(dsm_ras, "PERCENT_RISE")  # or use DEGREE
    out_slope.save(slope_ras)
    # calculate aspect
    print("calculate aspect...")
    aspect_ras = os.path.join(fgdb, aspect_name)
    out_aspect = arcpy.sa.Aspect(dsm_ras)
    out_aspect.save(aspect_ras)
def CorrectExtent(ext, cellsize):
    ext.XMin = divmod(ext.XMin, cellsize)[0]
    ext.YMin = divmod(ext.YMin, cellsize)[0]
    ext.XMax = divmod(ext.XMax, cellsize)[0] + cellsize
    ext.YMax = divmod(ext.YMax, cellsize)[0] + cellsize
    return ext
if __name__ == '__main__':
    main()
The file geodatabase with the resulting rasters (DSM, slope, aspect), is about 1.5GB (compressed a little over 210MB). You can download it here: HannoverCityGML.zip - Google Drive
Jacob_JeffB
Thank you so much!
XanderBakker
You are welcome
