3D volume evaluation with WebScene widget
1223
04-10-2018 11:52 PM
Environnement_1Lausanne
Hello,
We are looking for a tool to calculate 3D volumes (selection of surface and then calculation of the elevation differences between 2 drone datasets).
Are there any already available tools or widgets for WebScene ?
If not, what would you recommend ? Do you have a documentation explaining how widgets can be developped ?
Thanks a lot for your help,
Best,
Aureline
RalucaNicola1
Hi Auerlie,
we don't have out of the box tools for calculating 3D volumes. I guess you could build your own, but it probably wouldn't be extremely accurate. I didn't really understand your workflow: what do you mean by selection of surface?
I imagine that if you wanted to calculate the volume between two surfaces, you would have to draw a polygon or somehow select the area for which you want to calculate the volume. Then you could split the polygon in a grid and for each point in the grid I would get the elevation in each of the surfaces and then calculate the volume as grid cell area * height difference. Summing up the volumes for each of the cuboids should you give you an approximation of the whole volume (not very accurate though).
As for making a widget out of it, check out this tutorial: Create a custom widget | ArcGIS API for JavaScript 4.6 or have a look at this video from devsummit 2017: Building Your own Widget with ArcGIS API for JavaScript - YouTube
Raluca
