ArcGIS Maps SDKs Native Blog
Other Boards in This Place
Latest Activity
(186 Posts)
MichaelBranscomb
Esri Frequent Contributor
Version 100.15.5 of the ArcGIS Runtime SDKs for Android, iOS, Java, .NET, and Qt is now available. This patch includes bug fixes and 3rd party library updates.
Read more...
more
3 0 112
DonKemlage
In this blog post, we will take an ArcGIS Maps SDK for Qt code snippet that uses the prior asynchronous programming pattern of the Qt/C++ Signal and Slots and show you how to convert it to the new QFuture asynchronous programming pattern.
Read more...
more
4 0 139
MichaelBranscomb
Version 100.15.4 of the ArcGIS Runtime SDKs for Android, iOS, Java, .NET, and Qt is now available. This patch includes bug fixes and 3rd party library updates.
Read more...
more
3 0 1,060
Rachael_Ellen
New ArcGIS Blog PostWe’re excited to share the key timings and events about the upcoming ArcGIS Maps SDK for Flutter Maps beta release!
Read more...
more
2 0 300
Rachael_Ellen
New ArcGIS Blog PostAndrew Bladon shares how he built a full stack Qt Maps SDK app to identify the best climbing locations using a weather forecast API!
Read more...
more
3 0 319
DavidFeinzimer
Dejavu is available now as a Swift package for use in your own Swift projects and applications.
Read more...
more
6 0 302
Rachael_Ellen
New ArcGIS Blog PostVivian Quach shares how to incorporate Apple's SF Symbols® into an ArcGIS Maps SDK for Swift app!
Read more...
more
4 0 161
Rachael_Ellen
New ArcGIS Blog Post! This blog demonstrates how to integrate RESTful services, such as the places service, with the Native Maps SDKs by making HTTPS requests using native development frameworks.
Read more...
more
2 0 318
MarkBaird
With the recent long-term support (LTS) release of Java 21, JavaFX 21 and support for the new JDK coming in the 8.4 release of Gradle, the Java Maps SDK team have been busy testing our 200.2 release to make sure everything is working correctly with this latest LTS version of Java.
With testing successfully completed, we are pleased to announce the 200.2 release of the Java Maps SDK supports Java 21.  Our system requirements page has been updated and our Gradle starter project has also been modified to ensure it is compatible with Java 21.
The upgrade path for developers wanting to switch to Java 21 is very simple and only the following versions will need updating in your Gradle build scripts:
  • Gradle 8.4
  • JavaFX Gradle Plugin 0.1.0
So, if you want to use Java 21 in your Maps SDK apps, it’s a great time to upgrade to our 200.2 release.
more
3 3 488
Rachael_Ellen
New ArcGIS Blog Post! Learn how to create a custom dynamic entity data source to wrap a data feed for use in your ArcGIS Maps SDKs for Native Apps applications.
Read more...
more
0 0 369
93 Subscribers
