Deleting in Model Builder
226
11-01-2024 04:47 PM
Cassie2025
I am learning how to use the model builder in ArcGIS Pro, and everything is pretty straightforward. However, I cannot seem to delete variables or tools once I have added them to the model. How does one go about deleting a variable or tool from the model they no longer want to use? Thanks!
Tags (1)
DanPatterson
MVP Esteemed Contributor
depends, but did you try a ... right-click on the tool, then cut
... sort of retired...
Cassie2025
I have used the right-click and then cut, I was just wondering if it was possible to just delete without cutting.
I also realized the if you cut a variable labeled as a parameter to delete it, the variable still exists as a parameter when you open the tool despite not being visible in the model builder.
Dale_Honeycutt
Use the Delete key
Cassie2025
Oh yep, I didn't realize delete and backspace are different keys on Windows laptops. I'm normally a Mac user 😅 Thanks!
