ArcGIS Maps SDKs Native Blog
Other Boards in This Place
Latest Activity
(223 Posts)
MichaelBranscomb
Esri Frequent Contributor
The ArcGIS Maps SDK for Local Server has been deprecated and will be retired in 2030. If you have applications that use Local Server, it is time to start planning your migration to the use of core capabilities provided directly by ArcGIS Maps SDKs for Native Apps.
Read more...
more
1 2 609
MichaelBranscomb
ArcGIS Maps SDK for Local Server 200.6 is an incremental compatibility release that provides support for geoprocessing and map packages created with the latest version of ArcGIS Pro, 3.4. You can use versions 200.0-200.6 of the ArcGIS Maps SDKs for .NET, Java, and Qt with this release of the Local Server SDK.
Read more...
more
0 0 502
Nicholas-Furness
The latest update to the ArcGIS Maps SDKs for Native Apps is now available, including the brand new ArcGIS Maps SDK for Flutter!
Read more...
more
3 0 429
Rachael_Ellen
New ArcGIS Blog Post!  Feature snapping support for the Geometry Editor is now available with the 200.4 release of the Native Maps SDKs.
Read more...
more
3 0 622
Rachael_Ellen
New ArcGIS Blog PostThree new field types that enhance the way date and time data is stored and managed is now available with the 200.4 release of the Native Maps SDKs.
Read more...
more
3 0 559
Rachael_Ellen
New ArcGIS Blog PostWith the 200.4 release of the Native Maps SDKs comes the ability to display OGC 3D Tiles format in the new 3D Tiles layer.
Read more...
more
4 0 890
Rachael_Ellen
New ArcGIS Blog Post! This blog demonstrates how to integrate RESTful services, such as the places service, with the Native Maps SDKs by making HTTPS requests using native development frameworks.
Read more...
more
2 0 614
MarkBaird
With the recent long-term support (LTS) release of Java 21, JavaFX 21 and support for the new JDK coming in the 8.4 release of Gradle, the Java Maps SDK team have been busy testing our 200.2 release to make sure everything is working correctly with this latest LTS version of Java.
With testing successfully completed, we are pleased to announce the 200.2 release of the Java Maps SDK supports Java 21.  Our system requirements page has been updated and our Gradle starter project has also been modified to ensure it is compatible with Java 21.
The upgrade path for developers wanting to switch to Java 21 is very simple and only the following versions will need updating in your Gradle build scripts:
  • Gradle 8.4
  • JavaFX Gradle Plugin 0.1.0
So, if you want to use Java 21 in your Maps SDK apps, it’s a great time to upgrade to our 200.2 release.
more
3 3 1,291
Rachael_Ellen
New ArcGIS Blog Post! Learn how to create a custom dynamic entity data source to wrap a data feed for use in your ArcGIS Maps SDKs for Native Apps applications.
Read more...
more
0 0 767
Rachael_Ellen
New ArcGIS Blog! This blog is the second in a series of articles which demonstrates how the beta release  of the ArcGIS Maps SDK for Java  (with ARM Linux support) can be used for IoT data recording apps.
Read more...
more
0 0 683
117 Subscribers
