Running Experience Builder Server on Different Ports
498
03-31-2023 10:16 AM
Gurunara
New Contributor III
Is it possible to run the experience builder server on different ports, by specifying different values for the port and https port..?
Gurunara
New Contributor III
In server/package.json, modify scripts/start to:
"cross-env EXB_HTTP_PORT=xxxx EXB_HTTPS_PORT=xxxx NODE_ENV=production node src/server"
Gurunara
New Contributor III
MichaelLev
Occasional Contributor III
I have not succeeded by Gurunara suggestion, but I succeeded by following the tip in ArcGIS Experience Builder install  in mid-page:
In the Portal App for EXB, add url with the <client-port-number>
In server folder, do: npm start -- --port <server-port-number> --https_port <client-port-number>
and in client folder, just do: npm start
In the browser, go to: https://localhost:<client-port-number>
vijaybadugu
I am getting Error: listen EACCES: permission denied 0.0.0.0:4001
