popupTemplate in Higher version(4.26) Arcgis api for js miss part of attributes like style or "onclick" event
261
06-08-2023 08:15 PM
jerry_liuyu
Higher version(4.26) Arcgis api for js miss part of attributes like style or "onclick" event.
There are two identical fileexcept for the version of Arcgis api for js,one is 4.26,the other is 4.10.
微信图片_20230609101811.pngStrangely, higher version file may lose some attributes.
Has anyone encountered this situation or known the reasons and solutions?
Here is the code and change the version4.10 to 4.26 to get two files:
<html lang="en">
<head>
<meta charset="utf-8" />
<meta name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title>
Intro to PopupTemplate | Sample | ArcGIS Maps SDK for JavaScript 4.10
</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet"
href="https://js.arcgis.com/4.10/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.10/"></script>
<script>
require([
"esri/Map",
"esri/layers/FeatureLayer",
"esri/views/MapView",
"esri/widgets/Legend"
], (Map, FeatureLayer, MapView, Legend) => {
// Create the map
const map = new Map({
basemap: "gray-vector"
// Create the MapView
const view = new MapView({
container: "viewDiv",
map: map,
center: [-73.95, 40.702],
zoom: 10
view.ui.add(new Legend({ view: view }), "bottom-left");
* The PopupTemplate content is the text that appears inside the
* popup. {fieldName} can be used to reference the value of an
* attribute of the selected feature. HTML elements can be used
* to provide structure and styles within the content. The
* fieldInfos property is an array of objects (each object representing
* a field) that is use to format number fields and customize field
* aliases in the popup and legend.
//const template = {
// // autocasts as new PopupTemplate()
// title: "{NAME} in {COUNTY}",
// content: [
// // It is also possible to set the fieldInfos outside of the content
// // directly in the popupTemplate. If no fieldInfos is specifically set
// // in the content, it defaults to whatever may be set within the popupTemplate.
// type: "fields",
// fieldInfos: [
// fieldName: "B12001_calc_pctMarriedE",
// label: "Married %"
// fieldName: "B12001_calc_numMarriedE",
// label: "People Married",
// format: {
// digitSeparator: true,
// places: 0
// fieldName: "B12001_calc_numNeverE",
// label: "People that Never Married",
// format: {
// places: 0
// fieldName: "B12001_calc_numDivorcedE",
// label: "People Divorced",
// format: {
// places: 0
const template = {
content: '<table class="table">'
+ '<tbody>'
+ '<tr><td style="width:30%;">NAME:</td><td style="text-align:left;">{NAME}</td></tr>'
+ '<tr><td>COUNTY:</td><td style="text-align:left;">{COUNTY}</td></tr>'
+ '<tr> <td style="text-align:center;" colspan="2"><a style="cursor: pointer;background-color:black;" onclick="alert(\'1\');">aLable1</a>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<a style="cursor: pointer;" onclick="alert(\'2\');">aLable2</a></td></tr >'
+ '</tbody>'
+ '</table> '
// Reference the popupTemplate instance in the
// popupTemplate property of FeatureLayer
const featureLayer = new FeatureLayer({
url: "https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/ACS_Marital_Status_Boundaries/Feat...",
popupTemplate: template
map.add(featureLayer);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
ReneRubalcava
Adding some HTML tags directly in the content will be sanitized, like links or click events. You can work around this in your app a couple of ways, like returning a function in the content or using CustomContent.
https://www.esri.com/arcgis-blog/products/js-api-arcgis/mapping/using-html-with-popups-in-the-arcgis...
https://developers.arcgis.com/javascript/latest/sample-code/popup-customcontent/
https://odoe.net/blog/custom-popup-content
JoelBennett
MVP Regular Contributor
See also this thread.
