Are the URL parameters case sensitive?
3856
10-16-2012 12:17 PM
MichaelWestmoreland1
noob getting up to speed. We're running ArcGIS version 10 Enterprise server and .Net.
I created a service from an .msd file.  I want to add it to ArcGIS.com.
The url appears to be case sensitive.  Would someone confirm this yes or no?
My Map -> Add -> Add layer from web -> URL: field
Mixed case this works.
servername.domain.org/ArcGIS/rest/services/ServiceName/FeatureServer/0
Lower case it don't. Throws two errs, one - can't connect, two - layer can't be added.
servername.domain.org/arcgis/rest/services/servicename/featureserver/0
A colleague tells me you have to add FeatureServer/0 at the end of the URL.
What's this do?
And I can't see everything that's in the URL field the end of it's truncated.  When I click in the box the text disappears.
So what's the complete line in the URL field?
MikeMinami
Esri Notable Contributor
In general terms, the URLs are case sensitive. In reality, some part of the URL are not case sensitive, but I think it's easier just to think that it is case sensitive.
As far as the /0 at the end...this indicates a particular layer. As feature services can have multiple layers in them, you can specify an index to get a particular one. If you don't specify the index, you get them all added to the web map.
thanks,
Mike
thanks,
Mike
Ok thanks, guess there's a nix server on the backend.
