Need layout with Map on left and tab container on the right
1372
05-13-2011 02:22 PM
JimDickerson
I took an ESRI sampe layout and tried to modify it so that I have a Map on the left and a TabContainer on the right.  The map shows up but there is nothing on the right.  Is there something wrong with this layout?
  <body class="soria">
      <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width:100%; height:100%;">
      <div id="header" dojotype="dijit.layout.ContentPane"  class="roundedCorners" region="top">
       HEADER
       </div>
      <div id="map" dojotype="dijit.layout.ContentPane" class="roundedCorners" region="center">Map</div>
     <div dojoType="dijit.layout.TabContainer" region="right" tabStrip="true">
                <div dojoType="dijit.layout.ContentPane" title="My first tab" selected="true">
                 Stuff
                </div>
                <div dojoType="dijit.layout.ContentPane" title="My second tab">
                    Lorem ipsum and all around - second...
                </div>
                <div dojoType="dijit.layout.ContentPane" title="My last tab" closable="true">
                    Lorem ipsum and all around - last...
                </div>
            </div>
            <!-- end TabContainer -->
      <div id="footer" class="roundedCorners" dojotype="dijit.layout.ContentPane" region="bottom">
        This is the footer section
      </div>
      </div>
  </body>
KellyHutchins
Esri Notable Contributor
You were close - you just needed to assign a width to the right pane that contains the tab. You can do this by setting an id for the tab pane to id="rightPane". The sample associates a css style with this id to set the pane's width to 30%.
Here's the modified code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.2/js/dojo/dijit/themes/soria/soria.css">
    <style type="text/css">
      html, body {
        height: 100%; width: 100%; margin: 0;
      body{
        background-color:white; overflow:hidden;
        font-family: "Trebuchet MS";
      .roundedCorners{
        -moz-border-radius: 4px;
      #header {
        border: solid 2px #7EABCD;
        background-color:white; color:peru; font-size:18pt;
        text-align:center; font-weight:bold; height:60px;
      #subheader {
        font-size:small;
        color: peru;
      #rightPane{
        color:peru;
        border: solid 2px cornflowerblue;
        width:30%;
        overflow:hidden;
      #map {
        border:solid 2px cornflowerblue;
        padding:0;
      #footer {
        background-color:white;color:peru;font-size:10pt; text-align:center; height:40px;
      .soria .dojoxGridHeader .dojoxGridCell   {
        color:peru !important;
    </style>
<script type="text/javascript">
  var djConfig = {
    parseOnLoad: true
</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.2">
</script>
  dojo.require("dijit.dijit"); // optimize: load dijit layer
  dojo.require("dijit.layout.BorderContainer");
  dojo.require("dijit.layout.ContentPane");
  dojo.require("dijit.layout.TabContainer");
  dojo.require("esri.map");
  dojo.require("esri.toolbars.draw");
  dojo.require("esri.layers.FeatureLayer");
  dojo.require("esri.tasks.query");
  dojo.require("dojox.grid.DataGrid");
  dojo.require("dojo.data.ItemFileReadStore");
  var map, toolbar;
  var featureLayer;
  function init() {
    var initialExtent = new esri.geometry.Extent({
      "xmin": -13092200,
      "ymin": 3691751,
      "xmax": -12538796,
      "ymax": 3880092,
      "spatialReference": {
        "wkid": 102100
    map = new esri.Map("map", {
      extent: initialExtent
    dojo.connect(map, 'onLoad', function(map) {
      dojo.connect(dijit.byId('map'), 'resize', resizeMap);
    var basemapUrl = "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer";
    var featureLayerUrl = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/EarthquakesFromLastSevenDays/MapServer/0";
    var basemap = new esri.layers.ArcGISTiledMapServiceLayer(basemapUrl);
    featureLayer = new esri.layers.FeatureLayer(featureLayerUrl, {
      mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
      outFields: ["region,magnitude,depth,objectid"]
    featureLayer.setSelectionSymbol(new esri.symbol.SimpleMarkerSymbol().setSize(8).setColor(new dojo.Color([160, 214, 238])));
    map.addLayer(basemap);
    map.addLayer(featureLayer);
  function resizeMap() {
    //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in
    //the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_faq.htm
    var resizeTimer;
    clearTimeout(resizeTimer);
    resizeTimer = setTimeout(function() {
      map.resize();
      map.reposition();
    }, 500);
  //show map on load
  dojo.addOnLoad(init);
</script>
</head>
      HEADER
    </div>
    </div>
    <div id="rightPane" dojoType="dijit.layout.TabContainer" region="right" tabStrip="true">
        Stuff
      </div>
      </div>
      </div>
    </div>
    </div>
  </div>
</body>
</html>
JimDickerson
Thanks Kelly,
I didn't see that relationship but I'm catching on.
Jim
