Automating capture of Extent from multiple mxds with multiple dataframes
4819
35
04-19-2011 03:14 PM
George_ChandeepCorea
I want to create a single shape file from multiple mxd's that have multiple frame sets with different extents in them. I have found/started a script to do this (attached) but can't figure out how to write the captured X&Y Max/Min into the shape file that is created for this. See output below. I also want it to write the scale and title of the frame as well as the file name of the mxd.
Would appreciate your help in completing this script.
>>> import arcpy, os, glob
... #path = 'c:\\temp\\george\\'
... path = 'P:\\2011\\Job_031_TownPlanning_SeriesProduction\\Working\\mxd\\1'
... os.chdir(path)
... mxds_List = glob.glob('*.mxd')
... count_Mapdocs = len(mxds_List)
... print 'Processing ' + str(count_Mapdocs) + 'map documents...'
... #Create Polygon Shapefile
... arcpy.CreateFeatureclass_management(path, 'extents.shp', "POLYGON")
... #Start Loop
... for mxd in mxds_List:
...     mapDoc = arcpy.mapping.MapDocument(mxd)
...     dataframe = arcpy.mapping.ListDataFrames(mapDoc,'*')[0]
...     frameExtent = dataframe.extent
...     #Frame Scale
...     frameScale = dataframe.scale
...     #Frame Extent
...     ExtentXMax = frameExtent.XMax
...     ExtentXMin  = frameExtent.XMin
...     ExtentYXax  = frameExtent.YMax
...     ExtentYMin  = frameExtent.YMin
...     point_object = mxd.shp
...     #Write in table scale
...     #Write in table
Processing 14map documents...
Runtime error <type 'exceptions.AttributeError'>: 'str' object has no attribute 'shp'
AlessandroCinnirella
the problem in you code is mxd.shp is interpreted as mxd = variable (defined in the for loop "for mxd in mxds_List") and .shp is interpreted as an attiribute of your mxd variable.
try changing the name of the point object.
Ciao,
AC
When I use
arcpy.CreateFeatureclass_management(path, 'mxd2.shp', "POLYGON")
point_object = mxd2.shp
I get...
  File "P:\2011\Job_031_TownPlanning_SeriesProduction\Working\extent.py", line 29, in <module>
NameError: name 'mxd2' is not defined
JakeSkinner
Esri Esteemed Contributor
Here is some sample code that I was able to get working. You will need to create an array and add the XMAX, XMIN, etc to the array to create the polygon feature. Then you can create a feature class/shapefile from this array. I had trouble getting the Append tool to work with the array feature so I created a feature class for each extent, merged them together, and then deleted the original extent feature classes.
import arcpy, glob, os
from arcpy import env
from arcpy import mapping
env.overwriteOutput = True
path = r"C:\temp"
mxdList = glob.glob(path + "\*.mxd")
env.workspace = r"C:\temp\Test.gdb"
y = 1
for mxd in mxdList:
    mxd2 = mapping.MapDocument(mxd)
    dataframe = mapping.ListDataFrames(mxd2, "*")[0]
    XMAX = frameExtent.XMax
    XMIN = frameExtent.XMin
    YMAX = frameExtent.YMax
    YMIN = frameExtent.YMin
    pnt1 = arcpy.Point(XMIN, YMIN)
    pnt2 = arcpy.Point(XMIN, YMAX)
    pnt3 = arcpy.Point(XMAX, YMAX)
    pnt4 = arcpy.Point(XMAX, YMIN)
    array = arcpy.Array()
    array.add(pnt1)
    array.add(pnt2)
    array.add(pnt3)
    array.add(pnt4)
    array.add(pnt1)
    polygon = arcpy.Polygon(array)
    arcpy.CopyFeatures_management(polygon, "Polygon_Extent" + "_" + str(y))
    y = y + 1
list = []
lstFCs = arcpy.ListFeatureClasses("Polygon_Extent*")
for fc in lstFCs:
    list.append(fc)
arcpy.Merge_management(list, "Extent")
for item in list:
    arcpy.Delete_management(item)
J, Thanks for the code...
When I run it I got the following
  File "P:\2011\Job_031_TownPlanning_SeriesProduction\Working\mxd\extent_creation.py", line 32, in <module>
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 1943, in CopyFeatures
    raise e
ExecuteError: ERROR 000210: Cannot create output Polygon_Extent_1
Failed to execute (CopyFeatures).
I tried to open/close the file
    TempFile = open(polygon, "Polygon_Extent" + "_" + str(y)) # open file
    TempFile.close() # close file
    y = y + 1
but then get
TypeError: coercing to Unicode: need string or buffer, Polygon found
I am using Python 2.65 which came with ArcGIS 10.
Thanks for your assistance,
JakeSkinner
Do you have your env.workspace set to a File Geodatabase?  Can you post the entire code you are using?
deleted-user-1T_bOHag6M8d
I recently created an application very similar to what you are looking for. However, my application only captures the largest dataframe in each map. But I think you could easily adapt my code using a for loop for the dataframes. I've attached a zip file of my application.
You'll find my code in the Scripts folder.
Nope. How would I do this?
It is the same that you sent me with just the changes I included.
JakeSkinner
To set the environment workspace, you will use arcpy.env.workspace.  Ex:
arcpy.env.workspace = r"C:\data\Philadelphia.gdb"
It will still help to post all of your code.  I can check to see if there are any errors with the changes you made.
Thanks Jake.
Please see the attached script and rar file with some of the MXD's I am trying to get the extents from. I appreciate your time.
With this code I now get the following errors. I'm not sure why some values (YMax/Min? and Pnt3&4) get reported as Not a Number (NaN)
P:\2011\Job_031_TownPlanning_SeriesProduction\Working\mxd\1
<geoprocessing Map object object at 0x15D750A0>
<geoprocessing Data Frame object object at 0x15D7B4A8>
219157.947938379 8072842.27839025 377350.947938381 8205437.27839025 NaN NaN NaN NaN
377350.947938 219157.947938 8205437.27839 8072842.27839
219157.947938379 8072842.27839025 NaN NaN 219157.947938379 8205437.27839025 NaN NaN 377350.947938381 8205437.27839025 NaN NaN 377350.947938381 8072842.27839025 NaN NaN
  File "P:/2011/Job_031_TownPlanning_SeriesProduction/Working/mxd/1/extent_creation2.py", line 38, in <module>
best,
