handling spaces in variables in Python
2619
11-15-2010 09:28 PM
DustinEdge
Greetings All
I'm trying to write a script that takes a dataset from the drop-down option in a tool, extracts the filename and folder path from it, determine whether the folder is a normal folder or a gdb, queries the type of dataset it is (point, line, polygon, raster) and write it all to a text file.
Unfortunately, the way our file system is setup is causing me pain. Here's a typical filepath:
J:\MMPL\60153995\4. Tech Work Area\4.7 GIS\Mike11_data.gdb\DHI_CrossSections
* Note the spaces in the path
My problem is that when trying to run the script in PythonWin I have to insert the whole path in "" "" to get Python to see it as one variable.
If I don't, it thinks that only J:\MMPL\60153995\4. is the variable's contents
But that works as I can use os.path.dirname & os.path.basename to extract the filename & folderpath.
BUT....I can't use the variable in a Describe on that variable. It returns a 999999 RunTimeError.
The goal is to have a script that I can use to populate a data register of sorts. I wasn't expecting to get bogged down on this simple first bit...argh.
Any help would be greatly appreciated.
ChrisMathers
Try raw strings. You use an r flag at the begining of the string.
r'string'
DustinEdge
Hi Chris
It wasn't the raw strings that was causing the problem.... embarrassingly...it was me.
I was using a filepath that didn't exist...
Cheers
ChrisMathers
Ha! If I had a dollar for every typo and wrong path Ive had I could hire a programmer to do this stuff for me.
DaleHoneycutt
And I'd be retired, living in luxury in some tropical isle, drinking Pina Coloda's a boring everyone with how the Intersect tool works...
