How to build a SQL expression in Python
3094
10-05-2010 11:51 AM
JoshV
In light of ArcGIS Server not recognizing the "Query Builder" wizard when using the Select By Attributes tool, I'm wondering if there is a way to manually construct the Query Builder?  So for instance, (see attached picture) based on the user first selecting which feature layer they want to run query against, a second dropdown list would then show All the Attributes associated with that feature layer.  A third dropdown list would then contain the values from which attribute the user chose.  So for example, If I wanted to run this Query "Active" = 'N' on the Wells layer.  Does anyone have any python to get me started here?
many thanks
