Field type in Python. Please help
3973
09-30-2010 05:23 AM
RickyCraig
Hi all,
trying to build a model using a combination of model builder and python. I'm not a programmer so my preference is just model builder but I can't do a certain step without a python script (at least I can't think of a way).
I have a shapefile and I need to test whether or not it has a specific field name (I found a code for that in the ESRI help files) and also if it does have that field that it is of a particular type and length e.g. text and 15.
The ESRI script works fine for determining the presence of the field. I can't get the code adjusted to allow for the field type though.
The code allows for 2 outputs, essentially True or False, which i can use as preconditions for the rest of the model.
If anyone has a hint on how to alter this so that I can test whether the field is of the correct type and length that would be much appreciated.
Cheers
RDHarles
You could do something like this to test the TYPE and LENGTH, simply using an "if" statement:
loop = gp.listFields(In_Table, "*", "ALL")
field = loop.next()
while field:
    # List the name, length and type of every field in the shapefile
    print "Name:   " + field.Name
    print "Length: " + str(field.Length)
    print "Type:   " + field.Type+"\n"
    if field.name == "PlanzNr" and field.length == 20 and field.type == "TEXT":
        ...do something...
JoelCalhoun
FYI,  using the ListFields method with a feature class in a file geodatabase returns a field type of "string" not "text".  I'm not sure if this is different for shapefiles.
However if you are creating a new field in a feature class in a file geodatabase using the AddField method a type of "text" is required.  I'm not sure if this is different for shapefiles.
This is not the only difference.
A couple others are:
ListFields returns: Integer
AddField needs:    Long
List fields returns: SmallInteger
Addfield needs:     Short
I hope this helps,
Joel
RickyCraig
Hey guys,
thanks for the replies. I'll try your suggestions and see how far I get.
Cheers
