MakeTableView error 000732: Input Table...
563
05-12-2010 03:54 PM
PaulFrank
Im having some trouble with what should be easy code.  The program sets the dataset as the workspace and then creates frequency tables that are put in the dataset.  Then I want to make table views from those tables, but get this error:
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Table: Dataset lutypesum does not exist or is not supported
Failed to execute (MakeTableView).
The code works up to the point of creating the frequency tables because i can see them in ArcCatalog.  Perhaps I dont understand the locations of files and am not setting them correctly?  Later in the code i am also trying to make a table view from a table that i know is in the geodatabase directory and not the dataset.
Thanks so much for any help,
Paul Frank
Austin, Texas
