Pop-up window - mediaInfos - linechart values
4535
07-01-2014 11:58 AM
MaryWindsor
Does anyone know what parameters for the values are needed for the linechart?
https://developers.arcgis.com/javascript/jshelp/intro_popuptemplate.html says that
the values are dependent on the type of chart.
Although I find info on piecharts and barcharts, I cannot find what type of format the values take for the linechart.
I'm looking for a date to go on the x-axis and numbers to go on the y-axis.
Mary
TracySchloss
Honored Contributor
There is not room to put my whole code and it's not in production so I can't share it with you.  I have no idea how to navigate well in this new forum, I could barely get logged in, it took multiple tries to get this far,  Some things like yearList and rateList are the results of a queryTask, populated earlier in the code.  At least you have an idea of some syntax for the axes.
var lineChart = new Chart2D("chartDiv", {
        title: chartTitle,
        titlePos:"bottom",
        titleGap: 12,
        titleFont: "normal normal normal 13pt Arial"
   lineChart.addPlot("default", {
        type: "Lines",
        markers: true,
        hAxis: "x",
        vAxis: "y"});
      lineChart.addAxis("x", {
        title:"Rates by Year",
        titleOrientation:"away",
        labels: yearList,
        font: "normal normal normal 9pt Arial",
        majorLabels: true,
        minorTicks: false,
        minorLabels: false,
         microTicks: false });
      lineChart.addAxis("y", {
        title:rateNote,
        vertical: true,
        fixLower: "major",
        fixUpper: "major",
        min: 0,
        max: axisMax,
        minorTicks: false,
        minorLabels: true});
      lineChart.addSeries("Series 1", rateList, {
          stroke: { color: "red", width: 2 }
      var tip = Tooltip(lineChart, "default", {
        text : function(o) {
          var yr = yearList[o.x].text;
          var yrList = parseInt(yr) - 1;
          return ( yrList +'<br>' + o.y );
  lineChart.render();
MaryWindsor
The parameters I put in mediaInfos worked to make a piechart. After I switched the chart type to linechart, the linechart showed up but incorrectly placed the line. Without documentation, I'm not sure if there is a certain way to state parameters for the linechart so the data shows up correctly (Ex. x-axis values vs. y-axis values).
On the other hand, dojox charting seems to have additional formatting options which can be useful.
Along with looking at the sources provided, I came across this example using dojox: Info window with chart | ArcGIS API for JavaScript
I'll see what I can do.
Thanks for your help!
TracySchloss
Honored Contributor
        title: chartTitle,
        titlePos:"bottom",
        titleGap: 12,
        type: "Lines",
        markers: true,
        hAxis: "x",
        vAxis: "y"});
        labels: yearList,
        majorLabels: true,
        minorTicks: false,
        minorLabels: false,
        title:rateNote,
        vertical: true,
        fixLower: "major",
        fixUpper: "major",
        min: 0,
        max: axisMax,
        minorTicks: false,
  lineChart.render();
MaryWindsor
Thanks, Tracy!
I was able to get a line chart to work in my pop-up using dojo charting options.
Now it looks like I'll have to do a querytask as well for multiple rows of data for matching dates to show up for one feature layer.
Mary
