Feature not drawing after added to offline database, refresh map?
4064
07-01-2014 09:37 AM
ForrestKaye
I cannot get a new feature to draw immediately after I add it to the offline geodatabase I am using.  (It will draw once I pan or zoom) I am looking for a refresh() call but can't find any reference to it.  I saw this thread that seems similar and references a refresh() but I can't find it.
I am assuming what ever call is necessary to refresh the map drawing I should place it in the onResume() call?
  @Override
  protected void onResume() {
    super.onResume();
    // Call MapView.unpause to resume map rendering when the activity returns to the foreground.
    mMapView.unpause();
   //refresh map/layers here?
ForrestKaye
In case anyone is having this issue or has it in the future. I Revisited this problem after some time and fixed it.
It was due to architecture issues, and was solved by creating a global variable of a Geodatabase and always using that variable for database operations.  Previously I was creating new instances of a geodatabase and using that for inserts.
So here is what I do now:
static Geodatabase localGDB; //declare global variable in main activity
localGDB = new Geodatabase("path/to/local/my.geodatabase"); //instantiate geodatabase in on create or elsewhere
MyActivityWithGlobalVar.localGDB //reference localGDB variable in other activities in this way when doing anything to it
