I have a service which is published with an SDE datasource using a windows authentication connection. The server will always use the "arcgis" user for the database connection login, when consuming the REST mapservice or featureservice.
Instead I would like to the login to the database to be the authenticated user. Is it possible?
The server is set up with the Web Adaptor, and web-based authentication.
thanks
