Server Database Connection using Authenticated User
3738
06-30-2014 10:32 PM
MattPratap
I have a service which is published with an SDE datasource using a windows authentication connection.  The server will always use the "arcgis" user for the database connection login, when consuming the REST mapservice or featureservice.
Instead I would like to the login to the database to be the authenticated user.  Is it possible?
The server is set up with the Web Adaptor, and web-based authentication.
thanks
MartinAmeskamp
Hi Matt,
have yout tried installing the ArcGIS server to run under an AD account that has a login on your SQL Server?
Thanks, Martin
DanielGarcia
Hi Matt,
That is not posible.
ArcGIS Server use the user account defined in the installation progress (tipically arcgis account) to access data resources.
Regards
Daniel
