Bug in Edit?
4056
8
06-30-2014 10:04 AM
TimWitt
Hey everybody,
I have recently created a Draw App that uses Edit, to be able to edit graphics and text.
It can be found here: http://jsfiddle.net/timw1984/T27G4/
When I do the following steps there seems to be a problem though.
1) Write some text in the textbox on the right -> right-click the map and click on "Add Text"
2) Now right-click the text and choose "Edit"
3) This pops up a menu in which you can change color/Alignment or double-click the text and change what it says.
Once done I should be able to click the map and the menu should disappear, but it doesn't. I am using EDIT_TEXT constant to do this.
The weird part is, when I choose "Rotate/Scale" (which uses the SCALE constant) instead of "Edit", the same menu pops-up and now when I click on the map the menu disappears.
Am I doing something wrong or could this be a bug?
Tim
MatthewLofgren
Looking at the error, it looks like Text editing (maybe all points) requires Edit.EDIT_VERTICES, Edit.EDIT_TEXT (text only?), Edit.MOVE tools
n=this._enableBoxEditing(b,c,p);(a&e)===e&&(k=this._enableVertexEditing(b));(a&g)===g&&this._enableTextEditing(b);if(!h&&!k&&!n)throw Error("[esri.toolbars.Edit::activate] Unable to activate the tool. Check if the tool is valid for the given geometry type.");
The code below prevents the error, which makes the popup work as expected....
function createGraphicsMenu() {       // Creates right-click context menu for GRAPHICS       ctxMenuForGraphics = new Menu({});       ctxMenuForGraphics.addChild(new MenuItem({          label: "Edit",         onClick: function() {           if ( selected.geometry.type !== "point" ) {           editToolbar.activate(Edit.EDIT_VERTICES, selected);           } else {             editToolbar.activate(Edit.MOVE | Edit.EDIT_VERTICES | Edit.EDIT_TEXT, selected);           }         }        }));
JeffPace
i am getting
Uncaught Error: [esri.toolbars.Edit::activate] Unable to activate the tool. Check if the tool is valid for the given geometry type. edit.js:22
w.activate edit.js:22
ctxMenuForGraphics.addChild.MenuItem.onClick (index):118
k.onItemClick _MenuBase.js:8
(anonymous function) _MenuBase.js:4
JeffPace
odd. ok it is coming back as a point.  Which is good.  You are setting the point with a textsymbol properly.
however when you pass that to
editToolbar.activate(Edit.EDIT_TEXT, selected);
i get the
Which is why you cant close it, because it wasnt properly created.
What I can't figure out is, why not? it looks like everything is fine.
TimWitt
Hey Jeff,
thanks for checking it out.
I know, its a headscratcher, especially since all the functions of the "Edit" tool work properly (you can change alignment and change the color of the text) it just doesn't close.
Tim
JeffPace
as much as you can sniff an obfuscated API, it looks like your point is failing the _IsTextSymbol internal check of edit.js
TimWitt
I wonder if anyone has a working example that lets text be edited, I just don't see why it shouldn't work.
Nevermind I found a working example here.
The difference here is that they declare a point first to get the location of the text, I feed it the location directly. Could that cause the issue? If so, how would I solve that problem?
MatthewLofgren
JeffPace
        label: "Edit",
          } else {
nicely done.  I got to there in the code, but couldnt get the solution out.  excellent
TimWitt
Matt,
great job! I still wonder if this is a bug maybe?
Thanks anyways!
Tim
