Moving between code and buttons
1196
06-27-2014 12:18 PM
jaykapalczynski
Honored Contributor
I have 4 Buttons...
the first two seems to work fine.
....The first one allows the user to draw a polygon
....The Second one allows the user to draw Freehand
I click the 3rd and it pauses the first 2 and a single click in the map highlights the Region
So far so good
After Clicking the 3rd button and doing a map selection
Go back and click one of the first 2 buttons to Draw....the drawing works fine BUT you can single Click and select a Region which was the code in the 3rd Button.
I still cant seem to figure out how to Stop that code from running on a Feature Map Click (from the third button)
Can anyone place their eyes on the source code of this page and see what I am doing wrong?
https://fwisweb1.dgif.virginia.gov/dgifmapping/DataExtract3.html
KenBuja
MVP Esteemed Contributor
So where are you defining all the actions? Is this what you're trying to do? You have to add in a reference to "dojo/on"
            function RegionSelection() {                  if (action1 != undefined) {                     action1.pause();                 }                 if (action2 != undefined) {                     action2.pause();                 }                 if (action4 != undefined) {                     action4.pause();                 }                 if (action3 == undefined) {                     alert("RegionSelection7");                      map.graphics.clear();                      var highlightSymbol = new SimpleFillSymbol(                     SimpleFillSymbol.STYLE_SOLID,                     new SimpleLineSymbol(                     SimpleLineSymbol.STYLE_SOLID,                     new Color([255, 0, 0]), 1),                     new Color([125, 125, 125, 0.35]));                      action3 = on.pausable(petroFieldsFL2, "click", function (evt) {                         map.graphics.clear();                         highlightGraphic = new Graphic(evt.graphic.geometry, highlightSymbol);                         map.graphics.add(highlightGraphic);                          var query = new Query();                         query.geometry = highlightGraphic.geometry.getExtent();                     });                      //petroFieldsFL2.on("click", function (evt) {                     //    map.graphics.clear();                     //    highlightGraphic = new Graphic(evt.graphic.geometry, highlightSymbol);                     //    map.graphics.add(highlightGraphic);                      //    var query = new Query();                     //    query.geometry = highlightGraphic.geometry.getExtent();                     //})                  }                 else {                     action3.resume();                 }              }
jaykapalczynski
Honored Contributor
I was able to trick it with the code in REd below....This is the only way I can figure out how to turn off the Feature Map Click in the Third Button...
I know this is not the right way...there has to be a more correct way.....Any thoughts?
    <button id="polygon"
            data-dojo-type="dijit/form/Button"
            data-dojo-props="iconClass:'polyIcon', showLabel:false">
              Polygon
    </button>
    <button id="freehandpolygon"
            data-dojo-type="dijit.form.Button"
            data-dojo-props="iconClass:'freehandIcon', showLabel:false">
              Freehand
    </button>
    <button id="RegionSelection"
              RegionSelection
    </button>
    <button id="Buffer"
              Buffer
     </button>
      var action1, action2;
      var action3, action4;
      registry.byId("polygon").on("click", function() {
   action2.pause();
   action3.pause();
   action4.pause();
  if (action1 == undefined) {
   activateTool(this.id);
   else {
   action1.resume();
       registry.byId("freehandpolygon").on("click", function() {
   action1.pause();
   action3.pause();
   action4.pause();
  if (action2 == undefined) {
   //alert("Freehand");
  else {
   action2.resume();
     registry.byId("RegionSelection").on("click", function() {
   action1.pause();
   action2.pause();
   action4.pause();
   action3 = RegionalSelectionMap(map);
         else {
                     action3.resume();
     registry.byId("Buffer").on("click", function() {
   action1.pause();
   action2.pause();
   action3.pause();
  if (action4 == undefined) {
   action3 = FourthButton(map);
  else {
   action4.resume();
        function RegionalSelectionMap() {
  selectionToolbar.deactivate();
        function FourthButton() {
KenBuja
jaykapalczynski
Honored Contributor
The other two buttons work great....
MODIFY: THANKS...I was missing the Dojo/on
Exactly what I needed....Learning everyday....much appreciated.
     var action1, action2, action3;
                action2.pause();
            if (action3 != undefined) {
                action3.pause();
    else {
         action1.resume();
                action1.pause();
                action3.pause();
    else {
     action2.resume();
                action1.pause();
                action2.pause();
                    action3 = on.pausable(petroFieldsFL2, "click", function(evt) {
         else {
             action3.resume();
        function activateTool(tool) {
          // The draw.activate expects a string like "polygon" or "freehand_polygon".
          selectionToolbar.activate(tool);
