Accessing coded value domains from Feature Set
2652
06-25-2014 08:34 AM
BryanBlaisdell
Hopefully this is an easy question:
Is there a way to access coded value domains from a FeatureSet?  I am running a table with coded domains through QueryTask, and half-expected the domains to be accessible from the resulting FeatureSet object "field" property.
However, when I run the Query and check my result properties for "fields," all I see is "name, type, alias, length".  Am I looking in the wrong place?  What is the best way to access a domain from a QueryTask result?
Thanks in advance!
Bryan
BrandonVan_Horn
This would be a good one to get answered. I am having the same problem.
ReneRubalcava
Esri Frequent Contributor
You can find that information in the fields property of the layer.
Each field will have a domain property associated with it and will look something like this.
  "name":"Enabled",
  "type":"esriFieldTypeSmallInteger",
  "alias":"Enabled",
  "domain":{
    "type":"codedValue",
    "name":"EnabledDomain",
    "codedValues":[
        "name":"False",
        "code":0
        "name":"True",
        "code":1
