//Add Web Mapping Services (WMS) var layer1 = new WMSLayerInfo({name: '1',title: 'name1}); var layer2 = new WMSLayerInfo({name: '2',title: 'name2'}); var resourceInfo = {extent: new Extent(-126.40869140625, 31.025390625, -109.66552734375, 41.5283203125, {wkid: 4326}),layerInfos: [layer1, layer2]}; var wmsLayer = new WMSLayer('http://nowcoast.noaa.gov/wms/com.esri.wms.Esrimap/obs', {resourceInfo: resourceInfo,visibleLayers: ['1', '2']}); map.addLayers([wmsLayer]);
Solved! Go to Solution.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Map with WMS</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var map; require([ 'esri/map', 'esri/layers/WMSLayer', 'esri/layers/WMSLayerInfo', 'esri/geometry/Extent', 'dojo/_base/array', 'dojo/dom', 'dojo/dom-construct', 'dojo/parser', 'dijit/layout/BorderContainer', 'dijit/layout/ContentPane', 'dojo/domReady!' ], function(Map, WMSLayer, WMSLayerInfo, Extent, array, dom, domConst, parser) { parser.parse(); map = new Map('map', { basemap: 'streets', center: [-96, 37], zoom: 4 }); var layer1 = new WMSLayerInfo({}); var resourceInfo = { extent: new Extent(-126.40869140625, 31.025390625, -109.66552734375, 41.5283203125, { wkid: 4326}), layerInfos: [layer1] }; var wmsLayer = new WMSLayer('http://nowcoast.noaa.gov:80/wms/com.esri.wms.Esrimap/obs?', { resourceInfo: resourceInfo, visibleLayers: ['world_countries_label','world_countries','RAS_RIDGE_NEXRAD','OBS_MET_TEMP'], }); wmsLayer.version = "1.1.1"; map.addLayers([wmsLayer]); }); </script> </head> <body class="claro"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" style="overflow:hidden;"> </div> </div> </body> </html>
Charles,
I think you need to actually specify your layer names in the visible layers (1 & 2 do not exist). Get your layer names from the capabilities file http://nowcoast.noaa.gov/wms/com.esri.wms.Esrimap/obs?service=wms&version=1.1.1&request=GetCapabilit...
The following code works in the sandbox (http://developers.arcgis.com/javascript/sandbox/sandbox.html)<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Map with WMS</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var map; require([ 'esri/map', 'esri/layers/WMSLayer', 'esri/layers/WMSLayerInfo', 'esri/geometry/Extent', 'dojo/_base/array', 'dojo/dom', 'dojo/dom-construct', 'dojo/parser', 'dijit/layout/BorderContainer', 'dijit/layout/ContentPane', 'dojo/domReady!' ], function(Map, WMSLayer, WMSLayerInfo, Extent, array, dom, domConst, parser) { parser.parse(); map = new Map('map', { basemap: 'streets', center: [-96, 37], zoom: 4 }); var layer1 = new WMSLayerInfo({}); var resourceInfo = { extent: new Extent(-126.40869140625, 31.025390625, -109.66552734375, 41.5283203125, { wkid: 4326}), layerInfos: [layer1] }; var wmsLayer = new WMSLayer('http://nowcoast.noaa.gov:80/wms/com.esri.wms.Esrimap/obs?', { resourceInfo: resourceInfo, visibleLayers: ['world_countries_label','world_countries','RAS_RIDGE_NEXRAD','OBS_MET_TEMP'], }); wmsLayer.version = "1.1.1"; map.addLayers([wmsLayer]); }); </script> </head> <body class="claro"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'" style="overflow:hidden;"> </div> </div> </body> </html>
Regards
Anthony
Charles,
No probs, glad you have got it working, please don't forget to mark the post as answered by checking the tick box on my post and hitting the up arrow,
Regards
Anthony
var layers = new WMSLayerInfo({}); var resourceInfo = {extent: new Extent(-126.40869140625, 31.025390625, -109.66552734375, 41.5283203125, {wkid: 4326}),layerInfos: [layers]}; var wmsRadarLayer = new WMSLayer('http://nowcoast.noaa.gov:80/wms/com.esri.wms.Esrimap/obs?', {resourceInfo: resourceInfo,visibleLayers: ['RAS_RIDGE_NEXRAD'],"visible":false, opacity:0.7}); wmsRadarLayer.version = "1.1.1";
