Create raster Datasets with Proportional Value Allocation
1017
06-19-2014 08:20 AM
EricShehadi
I am trying to create raster data sets from census block groups of a state that result in proportional allocation based on the density of the block group it is taking the value from.
Essentially, I am trying to create a raster like the one in the second picture on this website:
http://sedac.ciesin.columbia.edu/data/collection/gpw-v3/methods/grid
I have tried searching all over the place including in all of the related toolboxes within ArcGIS.
Has anyone ever created raster files like this before? Is there an easy way to proportionally allocate quantitative data in a raster?
I would appreciate any advice.
Than
Eric
LisaNelson
Than
Eric
Hi Eric- you may have figured this out already, but one technique is to rasterize the source polygons, then create a count of cells within the block group, then use that to divide the block group population.  Something like this (ArcGIS 10.2.2):
        #  Create the cell count raster
        pyLURas = Lookup(pyNonZeroPop,"Count")
        # Divide population raster by cell count raster; 'distributes' values into each cell in output
        outDistRas = Float(pyNonZeroPop) / Float(pyLURas)
        outDistRas.save(outputDistRaster)
Then, you can check the values by running zonal stats (Sum) on the outputDistRaster - sum should be equal to block group population (or nearly, given rounding, etc).
Hope this helps,
Lisa
