Path Names
697
5
06-17-2014 10:25 AM
BrettAuger1
Hi folks,
I need to get a list of path names for feature classes in a gdb. The gdb is configured something like this:
Myfeatures.gdb
Feature 1 Dataset
[INDENT]fc1, fc2,fc3 [/INDENT]
Feature 2 Dataset
Feature 3 Dataset
etc.
I am having trouble getting right down to the FC for a path. I tried using the os.path.join function but it doesn't seem to like lists and an input.
This is what I have so far for code.
import arcpy import os # Set the current workspace   gdbInput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\PIR_MR98copy.gdb" gdbOutput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\EmptyGisDeliverables_v14.gdb"  arcpy.env.workspace = gdbInput  # Create list of datasets in input gdb dsInput = arcpy.ListDatasets() #print dsInput  #Create list of fc in ds for ds in dsInput:     fcInput = arcpy.ListFeatureClasses(feature_dataset=ds)     print fcInput
This is what I get for results from previous code:
[u'AppraisalPoint'] [u'BlockHubs', u'BlockPolygon'] [u'RoadLine', u'RoadCrossing', u'RoadNotes', u'RoadHubs'] [u'RiparianLine', u'Riparian_SMZ_Buffer', u'LakeWetland', u'LakeWetlandLine']
Thanks.
Brett
IanMurray
Easiest thing to do would to create an empty list outside of your loop, then have each file path append itself to the list.
 import arcpy import os # Set the current workspace   gdbInput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\PIR_MR98copy.gdb" gdbOutput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\EmptyGisDeliverables_v14.gdb"  arcpy.env.workspace = gdbInput  # Create list of datasets in input gdb dsInput = arcpy.ListDatasets() #print dsInput  #make empty list to append file paths to. fclist = []  #Create list of fc in ds for ds in dsInput:     fcInput = arcpy.ListFeatureClasses(feature_dataset=ds)     for fc in fcInput:         filepath = [gdbOutput+ "/" + ds + "/" + fc]         fclist.append(filepath)  arcpy.env.workspace = gdbOutput for path in fclist:     if not arcpy.Exists(path):         print "no {}".format(path)     else:         print "yes {}".format(path)
IanMurray
Really, you just need to iterate through each feature class, and concatenate the workspace, the feature dataset and feature class name together.
import arcpy
import os
gdbInput = "C:\Users\iamurray\Desktop\Test.gdb"
#print dsInput
for ds in dsInput:
    for fc in fcInput:
        print gdbInput + "/" + ds + "/" + fc
This gives me
C:\Users\iamurray\Desktop\Test.gdb/Test1/TestFC2
C:\Users\iamurray\Desktop\Test.gdb/Test/TestFC
BrettAuger1
import arcpy
import os
#print dsInput
for ds in dsInput:
    for fc in fcInput:
This gives me
This seems to work for me too. However when I use a variable to collect the path names and use that variable as an input it only uses the last value. Is there a step that I need to do so the path names are returned in a list that can be used as an input for the next step. This is what I have so far again:
import arcpy
import os
#print dsInput
for ds in dsInput:
    for fc in fcInput:
        list = [gdbOutput+ "/" + ds + "/" + fc]
        print list
for path in list:
    else:
Thank you for your help.
Brett
IanMurray
BrettAuger1
This works smashingly. Thank you for your help. It is much appreciated.
import arcpy
import os
#print dsInput
fclist = []
for ds in dsInput:
    for fc in fcInput:
for path in fclist:
    else:
IanMurray
Glad it worked for you!
