Path Names
2085
06-17-2014 10:25 AM
BrettAuger1
Hi folks,
I need to get a list of path names for feature classes in a gdb. The gdb is configured something like this:
Myfeatures.gdb
Feature 1 Dataset
[INDENT]fc1, fc2,fc3 [/INDENT]
Feature 2 Dataset
Feature 3 Dataset
etc.
I am having trouble getting right down to the FC for a path. I tried using the os.path.join function but it doesn't seem to like lists and an input.
This is what I have so far for code.
import arcpy import os # Set the current workspace   gdbInput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\PIR_MR98copy.gdb" gdbOutput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\EmptyGisDeliverables_v14.gdb"  arcpy.env.workspace = gdbInput  # Create list of datasets in input gdb dsInput = arcpy.ListDatasets() #print dsInput  #Create list of fc in ds for ds in dsInput:     fcInput = arcpy.ListFeatureClasses(feature_dataset=ds)     print fcInput
This is what I get for results from previous code:
[u'AppraisalPoint'] [u'BlockHubs', u'BlockPolygon'] [u'RoadLine', u'RoadCrossing', u'RoadNotes', u'RoadHubs'] [u'RiparianLine', u'Riparian_SMZ_Buffer', u'LakeWetland', u'LakeWetlandLine']
Thanks.
Brett
IanMurray
Honored Contributor
Easiest thing to do would to create an empty list outside of your loop, then have each file path append itself to the list.
 import arcpy import os # Set the current workspace   gdbInput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\PIR_MR98copy.gdb" gdbOutput = "Q:\PIR\GIS\Brett\GDB Import Tool\Test Data\EmptyGisDeliverables_v14.gdb"  arcpy.env.workspace = gdbInput  # Create list of datasets in input gdb dsInput = arcpy.ListDatasets() #print dsInput  #make empty list to append file paths to. fclist = []  #Create list of fc in ds for ds in dsInput:     fcInput = arcpy.ListFeatureClasses(feature_dataset=ds)     for fc in fcInput:         filepath = [gdbOutput+ "/" + ds + "/" + fc]         fclist.append(filepath)  arcpy.env.workspace = gdbOutput for path in fclist:     if not arcpy.Exists(path):         print "no {}".format(path)     else:         print "yes {}".format(path)
IanMurray
Honored Contributor
Really, you just need to iterate through each feature class, and concatenate the workspace, the feature dataset and feature class name together.
import arcpy
import os
gdbInput = "C:\Users\iamurray\Desktop\Test.gdb"
#print dsInput
for ds in dsInput:
    for fc in fcInput:
        print gdbInput + "/" + ds + "/" + fc
This gives me
C:\Users\iamurray\Desktop\Test.gdb/Test1/TestFC2
C:\Users\iamurray\Desktop\Test.gdb/Test/TestFC
BrettAuger1
import arcpy
import os
#print dsInput
for ds in dsInput:
    for fc in fcInput:
This gives me
This seems to work for me too. However when I use a variable to collect the path names and use that variable as an input it only uses the last value. Is there a step that I need to do so the path names are returned in a list that can be used as an input for the next step. This is what I have so far again:
import arcpy
import os
#print dsInput
for ds in dsInput:
    for fc in fcInput:
        list = [gdbOutput+ "/" + ds + "/" + fc]
        print list
for path in list:
    else:
Thank you for your help.
Brett
IanMurray
Honored Contributor
BrettAuger1
This works smashingly. Thank you for your help. It is much appreciated.
import arcpy
import os
#print dsInput
fclist = []
for ds in dsInput:
    for fc in fcInput:
for path in fclist:
    else:
IanMurray
Honored Contributor
Glad it worked for you!
