Javascript viewer shows unwanted transparency
3174
06-17-2014 01:48 AM
GeorgeMuammar
Hi I have WMS service created from 2 layers. One is a polygon shading and another from a PNG symbol.
When you view it with the javascript viewer you notice that the symbols are semi-transparent. You see this when the symbols overlap the polygon shading. You can see it here
Note there is no transparency set on the layers in the MXD.
I tried using this layer on ArcGIS online and there is no transparency effect! see here
When I use this layer in my javascript application I do notice the transparency effect. It should not be there.
Any ideas why this is happening or how to fix?
PS ArcGIS Server is v. 10.1
AndyBurns
Hi
Have you tried:
layer.setOpacity(1.0);
GeorgeMuammar
Hi
Have you tried:
Yes it doesn't change anything. I tried 0.2 and it gets very transparent, but 1.0 or anything higher gives the previous result.
The most worrying thing is that when I view the layer using the javascript viewer of ArcGIS Server I see the transparency.
This tells me it is not an error of my application.
Seems strange no one has encountered this before
AndyBurns
Hi
What version of AGS are you running?
