JS Dojo.create help
3184
8
06-12-2014 04:44 AM
MathewSuran
Hey everyone,
I am trying to incorporate the
dojo.create("a", { href: "foo.html", title: "Goto FOO!", innerHTML: "link" }, dojo.body());
with my code
dojo.create("img", {"class":"", "src": "images/test.jpg"}, 'legendPanel',"last");
to make my image clickable that references a specific url.  Does anyone know how to do this?  Or if there is a better approach using a different method?  Thanks!
JeffPace
This is the full code:
var legendDijit = new esri.dijit.Legend({         map: map,         layerInfos: layerInfo     }, dojo.create('div'));      dojo.create("img", {"class":"", "src": "foo.jpg"}, 'legendPanel',"last");      dojo.create("img", {"class":"", "src": "foo1.jpg"}, 'legendPanel',"last");      dojo.create("img", {"class":"", "src": "foo2.jpg"}, 'legendPanel',"last");                 dojo.byId('legendPanel').appendChild(legendDijit.domNode);      navigateStack('legendPanel');     if (dojo.isIE === 8) {         setTimeout(function () {             legendDijit.startup();         }, 100);     } else {         legendDijit.startup();     }
Is there an easier way to incorporate the "a href" code into the dojo.create("img") or somewhere after that references each image?
var a = dojo.create('a', {href: url, target: "_blank"}, 'legendPanel',"last");
dojo.create("img", {"class":"", "src": "foo.jpg"}, a);
var a1 = dojo.create('a', {href: url1, target: "_blank"}, 'legendPanel',"last");
dojo.create("img", {"class":"", "src": "foo1.jpg"}, a1);
var a2 = dojo.create('a', {href: url2, target: "_blank"}, 'legendPanel',"last");
dojo.create("img", {"class":"", "src": "foo2.jpg"}, a2);
JeffJacobson
This is how I would do it.
var img = document.createElement("img");
img.src = "images/test.jpg";
var a = document.createElement("a");
a.href = "foo.html";
a.appendChild(img);
document.getElementById("legendPanel").appendChild(a);
Should result in
[HTML]
<a href="foo.html"><img src="images/test.jpg" /></a>
[/HTML]
MathewSuran
Thanks for that, I'm going to try that out now.  Does anyone else have any suggestions or comments?
JeffPace
amd style
 var a = domConstruct.create('a', {href: links[key], target: "_blank"}, dom.byId('resultLinksTab'));
 var img = domConstruct.create('img', {src: "images/" + key + ".png"}, a);
 domClass.add(img, 'resultLink');
MathewSuran
        map: map,
        }, 100);
    } else {
JeffPace
MathewSuran
Jacob's worked but in the end Jeff's was money.  Big thanks!
JeffPace
thanks, and sorry to steal jacob.
I just encourage using AMD dojo at all times.  Helps in the learning of the API as well.
MathewSuran
For the project I am working on, for now, is in Legacy.  I would have liked to start learning AMD, but unfortunately I can not convert it at this time (deadlines).  Hopefully it will need a revamp to AMD in the future.  I'm sure I will need assistance on the next project that I will be starting from scratch in AMD.  Thanks again!
