Is there any way to add KML,KMZ and CSV file from local drive/folder in web app?
6953
6
06-09-2014 10:35 PM
GauriDeshmukh
Though it is mentioned that kml file has to be available publically(or hosted on server),
I am looking for a solution to add kml files only from local drive.
ScottGunn
You are right, the KML Layer requires a KML hosted on a URL.  So, assuming you have ArcGIS Server, you can get around this...I was able to implement the uploading of KML/KMZ files by publishing a geoprocessing task on my ArcGIS Server.  This is basically a Modelbuilder model that takes a KML file and converts it to a feature layer.  When published as a GP Service, this feature layer is then available on the server and can be added as a dynamic service layer.  Here's what my model looks like:
[ATTACH=CONFIG]34470[/ATTACH]
You can use esri/request to upload\retrieve the file from the server.
var uploadKml = new esriRequest({
   url: config.KML_Conv + "/GPServer/uploads/upload",
   form: dom.byId('uploadForm'),
   content: { "f": "json" }
  uploadKml.then(
   function(response) {
    var random = (new Date()).getTime();
    var itemID = response.item.itemID;
    var kmlTask = new Geoprocessor(config.KML_Conv + "/GPServer/KML_Conv3");
    var dataFile = new DataFile();
    dataFile.itemID = itemID;
    var params = {"KML": dataFile };
    kmlTask.outSpatialReference = map.spatialReference;
    //pass file name and random ID to callbacks for reference.  Note: cannot set ID to filename due to use of spaces or special chars
    var args = { fileName: response.item.itemName, random: random };
    kmlTask.submitJob(params, lang.hitch(args, completeCallback), lang.hitch(args, statusCallback), lang.hitch(args,errCallback));
   function (error) {
    console.log("An error has occured: " + error);
Here's the callback:
function completeCallback(jobInfo){
   var kmlURL = config.KML_Conv + "/MapServer/jobs/";
   var kmlLayer = new ArcGISDynamicMapServiceLayer(kmlURL + jobInfo.jobId);
   map.addLayer(kmlLayer);
   $(".alert button#" + jobInfo.jobId).one("click", function() {
    map.removeLayer(kmlLayer);
   //zoom to new layer
   on(kmlLayer, "Load", function() {
    map.setExtent(kmlLayer.fullExtent, true);
Here's some more information on GP services:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00570000005w000000
You could presumably publish another Model as a Geoprocessing Task that handles CSV files in the same fashion...
GauriDeshmukh
Thanks sagunn  got new approach 🙂
I tried by this way -
I converted the input kml to geojson format and then geojson to esri format.then added as esri graphics on map.
GauriDeshmukh
  Why you have used dynamic service layer, is there any reason?
Instead of ArcGISDynamicServiceLAyer, we can use directly
                var kmlLayer = new esri.layers.KMLLayer(url);
JeffJacobson
You can add local CSV using this library:
https://github.com/WSDOT-GIS/CSV-Reader
GauriDeshmukh
This is great...thanks a lot jacobsj 🙂
this is what i wanted for csv.
but still struggling with adding kmz locally.
how to convert kmz into kml or unzip kmz and read its contents.
JeffJacobson
Note that I haven't personally used the libraries listed below, but they look like they will do what you want.
  • For unzipping the KMZ archive (which is just a ZIP archive containing KML): zip.js.
  • For converting KML to GeoJSON: mapbox/togeojson.
  • To convert from GeoJSON to ArcGIS JSON: Terraformer.ArcGIS. (This library is written by Esri.)
